WINDER1987
Do you have a price yet on this ? Will it still be $85
DranttelSS
- Oct 9, 2014
- St. Peter MN
- 2007 Yamaha Attak
Just got the plate from Travis yesterday. First impressions, looks fantastic! I will be testing its fit later tonight.
DranttelSS
- Oct 9, 2014
- St. Peter MN
- 2007 Yamaha Attak
Fits great! Order them up guys, it's a great product for the price!
bleedyamaha
- Sep 28, 2013
- Northern Iowa
Do you see the need for a belly pan protector like on the Viper for the brake rotor and the chain case area???
bleedyamaha
- Sep 28, 2013
- Northern Iowa
Do you see the need for a belly pan protector like the Viper for the brake rotor and chain case areas ?
AXR
- May 5, 2007
- Central NY
- Current: 2017 SideWinder L-TX LE
Past: 2015 Sr Viper R-TX SE, 2008 Apex RTX, 2002 Sx Viper, 1997 XTC 600, 1991 Doo Formula Plus.
This plate does nothing to protect the Chain Case, like the OEM rear plate on the vipers correct?
AXR
- May 5, 2007
- Central NY
Whoopsy. You beat me to it.Do you see the need for a belly pan protector like the Viper for the brake rotor and chain case areas ?
Dieselxtx
- Feb 21, 2016
- Fox Lake, WI
- 2017 Sidewinder BTX LE
2012 Nytro XTX 1.75
Is there access for oil filter?
WINDER1987
Is this up on the website yet?
DranttelSS
- Oct 9, 2014
- St. Peter MN
- 2007 Yamaha Attak
No it's all for the heat exchanger and oil filter... If your looking for chaincase protection I would look at the Racewerx protectors
DranttelSS
- Oct 9, 2014
- St. Peter MN
- 2007 Yamaha Attak
Same setup as the vipers but I don't think the Viper full skid plate will fit this sled
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
This plate takes the place of the thin factory plates on the underside. You remove them and then attach the skid plate with 4 bolts. Still allow for quick and easy oil changes.
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
2018 snoscoot
Yes the skid plate is on the website and in the online store.
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
2018 snoscoot
Thanks Nick for fitting this up! Greatly appreciate it.
WINDER1987
Does the skid plate have to be removed for an oil change or is there an access door for oil changes ?
- 13K
- 8K
