hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
So now your relying on 3 set screws ? Good luck
Bearings with set screws on an extended inner race have been around for a long time on snowmobile driveshafts. Early on some people were drilling and tapping the drive shaft and then seating the screw into the bearing race. This was not successful, and I think the reason it did not work was because the set screw could not dig into the hardened bearing race. There are several types of set screws and a cupped tip set screw is intended to cut and dig into the contact surface. The drive shaft is softer and therefore the set screws can dig in and get a good hold. Yamaha always used 2 set screws on the speedo bearing, but I opted to go with 3 for extra measure. As with anything, time will be the ultimate test but I have confidence this is going to work.
Jefro
- Aug 22, 2021
- Interlochen Michigan
- 2020 Thundercat iACT
2003 ZR 975
1996 ZRT 992 PS
In the past on other sleds I've used the NTN Formula Blue 1" bearings with a wide collar and 2 set screws. The set screws had an encased ball tip and would indent the shaft but if you failed to loctite them they would come loose eventually and spin on the shaft with predictable results. I have since gone back to an eccentric collar bearing on trail sleds and use the other on race sleds.
HABS 1
- Oct 22, 2015
- corunna,ontario
in the past on my apex and back in the 2s srx days ,they had 2 set screws holdin inner , and allways held fine almost to good , was a pita to bust em loose to replace a bearingSo now your relying on 3 set screws ? Good luck
NYTurbo
- Sep 26, 2017
- Ottawa
- Sidewinder
But you weren’t putting it on a worn shaft . Again good luck with this new concept but I’d personally ONLY use it on a good shaftin the past on my apex and back in the 2s srx days ,they had 2 set screws holdin inner , and allways held fine almost to good , was a pita to bust em loose to replace a bearing
- Feb 13, 2017
- Amston,CT
- Renegade 900 ACE,XF 9000 Crosstour,2024 Skidoo Renegade XRS 900R
This new concept drive shaft repair ,utilizing a UNWORN inboard section on the drive shaft ,as well as a pressed in collar on the bearing end I.D. is better than what came out of the factory all these years. The added plus is no new drive shaft expense,and no need for hours of dis assembl/re-assembly.there is no downside
STAIN
- Feb 29, 2004
- Vermont
- 2024 Arctic Cat Riot 9000
- Vermont
debating whether to install this from new, I am doing a track change on my new sled, and it would be the time to do it.
- Feb 13, 2017
- Amston,CT
No brainer for $170/shipping
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
Just loosen up the track then reach under sled and grab diveshaft on left side in tunnel and push up and down on it. If it has play you will feel it and bearing has spun and wore shaft.Thanks. That's what I needed.
Hoosiersnow
- May 19, 2015
- Indiana
- 18 cat 600 137
Good to know. I pulled the rear skid on Friday. Too bad I didn't see your message first. Now I need to figure out who to have rebuild the shocks.Just loosen up the track then reach under sled and grab diveshaft on left side in tunnel and push up and down on it. If it has play you will feel it and bearing has spun and wore shaft.
Sled is stored in off season in a garage a couple hours away so I'll have to wait until next time I'm that direction to take a look.
I have 2 sidewinders. One is brand new with zero miles. The other has 15k miles. 6k miles with the wedge. Both are getting this bearing, and the wedge. I can't stand problems.
sailor joe
- Apr 4, 2019
- ma
- 2016 RS VENTURE TF
2020 SIDEWINDER GT
slimjim, can I ask why you added the wedge at 9k miles? was the shaft worn on the DX or was it for insurance against failure of the bearing and shaft. JoeI have 2 sidewinders. One is brand new with zero miles. The other has 15k miles. 6k miles with the wedge. Both are getting this bearing, and the wedge. I can't stand problems.
Driveshaft was toast. Got a new driveshaft, and put the wedge in. No problems in 8k miles with the wedge. Just remembered I have had the wedge for 2 seasons, so a little over 8k miles. I sent the old driveshaft out and had it spray welded and turned to size. I keep it as a backup. There are 9 sidewinders in our crew.
sailor joe
- Apr 4, 2019
- ma
2020 SIDEWINDER GT
I have 4k miles on a 2020 stx gt, I have no idea what the driveshaft looks like but I will have to inspect it. The dealer says its fine but I doubt they actually checked it. Just wondering if I should just put in the wedge. I was advised not to put the wedge in until it needed it...so a little confused...with 9 sidewinders in your group, what is the consensus. JoeDriveshaft was toast. Got a new driveshaft, and put the wedge in. No problems in 8k miles with the wedge. Just remembered I have had the wedge for 2 seasons, so a little over 8k miles. I sent the old driveshaft out and had it spray welded and turned to size. I keep it as a backup. There are 9 sidewinders in our crew.
Put the wedge in on a new driveshaft. If it is worn, the wedge will likely not take up the slack. Get it checked, and start from there.
sailor joe
- Apr 4, 2019
- ma
2020 SIDEWINDER GT
thanks for the advise Jim...I'm going to do just that soon. I have heard that not all drive shafts wear but will check it. BOP has some pictures of different shafts and I will use that as a guide. JoePut the wedge in on a new driveshaft. If it is worn, the wedge will likely not take up the slack. Get it checked, and start from there.
