I think it will be fine.I still think even with this design the wear in shaft should be addressed either with shim,welding or maybe even Epoxy. The load on bearing is not going to be centered under the bearing. Kind of like a offset rim can be hard on a bearing. It would be ideal if the brake hub could be machined narrower at back and collar extended and splined. Would not need the set screws at that point and sleeve would have support at both sides of bearing if fit was good. Probably cost prohibitive though. Hope this proves successful.
I can't see how it's any different than bearings that have set screw collars on one side
Because the shaft isn’t wore out under them. You are probably right though.I think it will be fine.
Upstater57
- Apr 25, 2021
- New York
- 2022 Tcat EPS,
2014 ZR9000 (sold)
1978,1979,1980 SRX (sold)
Does anyone make a completely new shaft with better tolerances? Years ago there was a tool company in Connecticut that made better shafts for our Thundercats that did not twist or break. They worked great. Perhaps the best solution is a better shaft with a matching high quality bearing that has a better fit.
Turboflash
- Mar 18, 2019
- Southern MN
Seal: 54 x 65 x 8. (https://www.motionindustries.com/products/sku/00769416)Stock seal is 45x65x8. Collar was spec'd to 54mm OD as you can get a 54x65x8 seal.
Let me know how it works out for you. I could likely make a custom one for you that has a key way slip fit between bearing and collar if needed.
CR SEALS (SKF)54X65X8 CRW1 R
Single Lip Oil Seal - Solid, 54 mm Shaft, 65 mm OD, 8 mm Width, CRW1 Design, Nitrile Rubber (NBR) Lip Material
Turboflash
- Mar 18, 2019
- Southern MN
IMO, if someone is going to make a new shaft from scratch for this application, then they may as well just make it so bearing presses on. Problem solved.Does anyone make a completely new shaft with better tolerances? Years ago there was a tool company in Connecticut that made better shafts for our Thundercats that did not twist or break. They worked great. Perhaps the best solution is a better shaft with a matching high quality bearing that has a better fit.
GR8BBQ
- Mar 23, 2018
- Hamlin, NY
- 2017 Yamaha SRViper X-TX SE
2017 Ski-Doo Blizzard 900 ACE
2001 Yamaha SXR 700 Triple
1995 Polaris Indy Lite
If you are going with a new shaft, then the original part plus the BOP driveshaft saver is a proven, easy, off the shelf solution.
Sorry, I thought you were talking about on a good shaft.Because the shaft isn’t wore out under them. You are probably right though.
I'm not sure if it would be an issue on worn shaft.
Hoosiersnow
- May 19, 2015
- Indiana
- 18 cat 600 137
Not sure if this is the best thread for this question - but I'm hoping to get at my sled this weekend to pull the shocks for rebuild.
I won't have a lot of time but is there a quicker way to check is the driveshaft is worn? I'm assuming I'd need to get the bearing accessible and check for movement. I've changed these bearings out on a Polaris but not yet on a procross so I'm not that familiar with that part of it.
- Feb 13, 2017
- Amston,CT
- Renegade 900 ACE,XF 9000 Crosstour,2024 Skidoo Renegade XRS 900R
The easy way is to call Travis at Barn of parts.You can check out the new concept drive shaft repair he offers.you are going to have the brake caliber off to inspect it ,you can fix it at the same time with a new bearing and collar assy. He can be reached at 717-821-9639Not sure if this is the best thread for this question - but I'm hoping to get at my sled this weekend to pull the shocks for rebuild.
NYTurbo
- Sep 26, 2017
- Ottawa
- Sidewinder
I would not install on a worn shaft .Sorry, I thought you were talking about on a good shaft.
- Feb 13, 2017
- Amston,CT
This is specifically made for a worn shaft INBOARD of the original inner race is where the collar is locked down with 3 set screws.He has a great video on his websiteI would not install on a worn shaft .
Turboflash
- Mar 18, 2019
- Southern MN
Travis (Barn of Parts) previously posted this:Not sure if this is the best thread for this question - but I'm hoping to get at my sled this weekend to pull the shocks for rebuild.
Tech Tip...Determining if driveshaft has spun
I get a lot of people that ask me what the easiest method is to determine if the drive shaft has been spinning so I wanted to share my findings. I find that removing the brake rotor and inspecting the backside of the hub is the quickest way to determine if you have an issue. If the shaft has...
NYTurbo
- Sep 26, 2017
- Ottawa
- Sidewinder
So now your relying on 3 set screws ? Good luck
- Feb 13, 2017
- Amston,CT
And the interference fit of the collar to the inner race of the bearing.Ride on
Hoosiersnow
- May 19, 2015
- Indiana
- 18 cat 600 137
Thanks. That's what I needed.Travis (Barn of Parts) previously posted this:
I get a lot of people that ask me what the easiest method is to determine if the drive shaft has been spinning so I wanted to share my findings. I find that removing the brake rotor and inspecting the backside of the hub is the quickest way to determine if you have an issue. If the shaft has...ty4stroke.com
- 7K
