Soupy
- Jan 10, 2017
- West Michigan
- 2017 Sidewinder LTX-LE
Last weekend we put around 600 miles on, no belt dust .last year I had a tin of dust.
Clutches run really cool . Biggest difference was the way the machine shifts now. It's so smooth.
XS825? Were the clutches hot before?
Joe ltx-le
- Mar 26, 2015
- Beaverbank-ns
- 2017 sidewinder ltx-dx
Yes xs825. My clutches never ran really hot , but with this belt the clutches are almost cold after a big run. Compared to an 850 I run with its night and day difference.XS825? Were the clutches hot before?
stevewithOCD
Yamaha, Make me Come Back
- Jan 1, 2008
- Live CT Ride MAINE
- 900 R
2006 Apex RTX
Joe, you blew like a jillion belts last year. What did you change?
Joe ltx-le
- Mar 26, 2015
- Beaverbank-ns
Dalton Secondary spring and helix. Plus the xs 825.Joe, you blew like a jillion belts last year. What did you change?
Yamarus
- Oct 4, 2021
- Russia
- Russia
- Yamaha Sidewinder B-TX LE 153
I replaced the belt today. I rode on a belt for less than 1000 km. What could be the reason for such damage? I drive a BTX through deep snow. I set the transmission to 21/49. Secondary spring epi purple acss-5. But the clutch gets very hot after the ride. The bearing on the short shaft is installed correctly.
I have now installed the xs825 belt.
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
View attachment 175295View attachment 175296
What offset are you running?
Setup to float or bolted solid secondary?
What is the EPI spring set at?
Helix?
Belt?
Primary weights and tune?
Offset?
There can be so many reasons why. Wrong offset, clutch sticking outward if it floats and not lining up, poor clutching, oil on belt, but looking at the belt I'd wager the offset is off completely just because the damage is on one side. You lucky you caught it before it blew to pieces.
Can you post some more pictures of the sides of the belt where it is damaged?
Yamarus
- Oct 4, 2021
- Russia
- Russia
The clutch settings are standard. I didn't change anything, just shifted the gear to 21/49. The EPI spring is set to 1-0. The belt is 8jp. The clutch is attached to a standard bolt.
I previously removed the 2mm on the secondary clutch. But when using a standard bolt, the clutch had a stroke. I returned the washer with a diameter of 2 mm. Before the removal of 2 mm, the offset was within acceptable values according to the instructions.
Today, during the trip, I observed revolutions in the region of 9100-9300 rpm. I think the belt started to collapse at high revs. I felt it and decided to stop and check it out.
sideshowBob
With that gearing you are easily fully shifting out the clutches to max overdrive so the belt speed at 9200rpm is very high and IMO you are overheating and also exceeding the belt strength and ability to survive under extreme conditions.
Yamarus
- Oct 4, 2021
- Russia
- Russia
The greatest damage to the belt is from the outside of the snowmobile, if you look at the belt when it is installed.
Yamarus
- Oct 4, 2021
- Russia
- Russia
What ideas can there be? Increase primary weights? I'm tired of being afraid to hit full throttle.With that gearing you are easily fully shifting out the clutches to max overdrive so the belt speed at 9200rpm is very high and IMO you are overheating and also exceeding the belt strength and ability to survive under extreme conditions.
KnappAttack
- Feb 19, 2004
- Welch MN
Doesn't answer most of the important questions... Offset being the most important.
Take the Purple EPI spring out for now and go back to the stock spring & settings, no need for more secondary spring being geared so low and on stock tune.
Yamarus
- Oct 4, 2021
- Russia
- Russia
In picture 5/8 it appears the belt may be burnt where the damage is.
- 14K
- 9K
