Yamarus
- Oct 4, 2021
- Russia
- Russia
- Yamaha Sidewinder B-TX LE 153
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
I disassembled the primary clutch. The spring was rubbing the clutch. I turned the spring over, I'll see what happens. The mileage is 3,700 km.
Tomorrow I will measure the offset.
View attachment 175330View attachment 175331
Springs are always going to rub, vibrate and wear the paint off. Its not the spring rubbing that caused the belt to break.
Yamarus
- Oct 4, 2021
- Russia
- Russia
I measured the displacement. There were no adjusting washers from the factory. There was a locking ring, I didn't take it off. I removed the 2mm from the rear clutch, but did not remove it from the float. When I put the clutch on, I had a gap of 2 mm, the clutch was floating. In the near future, I will take 2 mm off the float and try again.
The displacement with the washer (as it was from the factory) was ~ 61 mm. After killing 2 mm from the rear clutch, the offset is ~59 mm.
Don't take too much off. Whatever is removed from the back should also be removed on the spacer that slides over the retaining bolt.
2.5mm total is about the max.
Yamarus
- Oct 4, 2021
- Russia
- Russia
I removed 2 mm from the float (it was 4.25 mm, it became 4.05 mm). Do I need to install a standard spring and gears? Or replace only the EPI PURPLE spring with a standard one? Or to see how this assembly will work with the new offset?
I don't understand your math there.I removed 2 mm from the float (it was 4.25 mm, it became 4.05 mm). Do I need to install a standard spring and gears? Or replace only the EPI PURPLE spring with a standard one? Or to see how this assembly will work with the new offset?
Removing float requires adding shims around the outer spacer.
Yamarus
- Oct 4, 2021
- Russia
- Russia
If you want no float you must add machinery washers around that spacer pictured. You'd have to measure to come up with what's needed.The secondary clutch plane has been removed by 2 mm.
I removed 2 mm from the float.
The offset is now ~59 mm.
Yamarus
- Oct 4, 2021
- Russia
- Russia
Info
You have to measure the difference between where I marked one and two(also add on the width of that washer) and add machinery washers if you want zero float.Info
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
Removing float from secondary
This is how mine is set up. First I set my offset with the hurricane offset tool. Second I cut the aluminum plug to be flush with the clutch hub. This is my clutch bolt. The washer next to the aluminum plug holds my clutch from floating. The two small washers are used to set my belt deflection...
ty4stroke.com
Well why didn't you post that an hour ago....lol.Removing float from secondary
This is how mine is set up. First I set my offset with the hurricane offset tool. Second I cut the aluminum plug to be flush with the clutch hub. This is my clutch bolt. The washer next to the aluminum plug holds my clutch from floating. The two small washers are used to set my belt deflection...ty4stroke.com
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
Working today....Well why didn't you post that an hour ago....lol.
@YukonMP How's the snow where you are?Well why didn't you post that an hour ago....lol.
- 11K
