FindingPowder
- Feb 7, 2018
- Londonderry nh
- 2014 Sr Viper rtx
Hello everyone new to the site been following for a while tho, I too just installed a brand new thunder Products big venom kit in my 2014 SR viper RTX that is stock with a picked track and the flashed ecu.... However when I went on the trail to test it my engagement was still a little high probably around 3200 RPM and my top speed was still only in the 80s I installed the kit on six and one and put the weights in exactly how I got them I didn’t tamper with them. Any advice? I plan to do the airbox mod and Buy an MBRP trail exhaust soon
blueironranger
- Feb 3, 2009
- Iron Range MN
- 2014 Viper XTX
2009 Phazer MTX
80’s where? Hard pack, wind blown lake, freshly groomed trail? Makes a HUGE difference. If on hardpack then you may have the casting flash issue in the secondary clutch. Normal “trail conditions” I see low 90’s, crossing a wind blown lake, mid 80’s. 102 is the best ever under ideal conditions (-5*f and a HARD surface)
MattyG
- Nov 12, 2017
- 2016 Yamaha Viper LTX LE
I sent you a pm.
I have a 2016 Ltd with full hindle, pcv, hurricane airbox mod, studded, TP HH weight set per Terry. On trail conditions max rpm. Is 8500 rpm and 120 kmph. Secondary set to 6-1. Engagement is around 3400 rpm. Any help would be appreciated.
rbell14
Best to just call or email Thunder Products with your set up and they will be able to get you very close on first attempt.
- Locked
- 141K
