hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
Just put my cross shaft saver on your bent crosshaft.
Check the lower eyelet also.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
Anybody drill the shaft for grease zert and ports to shock bushing? Mines not bent but the bushing and shaft are worn just as bad as the bent one in the picture.
Big_Phil
- Feb 5, 2014
- Wasaga Beach, Ontario
- Sidewinder RTX LE
Put the steel lower shaft in from an rr artic cat or from an le viper. The part numbers are in the viper forum somewhere.
Big_Phil
- Feb 5, 2014
- Sidewinder RTX LE
View attachment 143594 View attachment 143595 View attachment 143596 The shock body isn’t looking great either but I told the old lady to get a hold of cannondale27 for the 160# spri
Yamaha replaced my shock under warranty. Looked pretty similar to the wear on yours.
There are better bushings to go in that eyelet. It's not sealed so grease only last a few hundred mi. Most of the FOX factory spec shocks use a soft rubber bushing that actually lasts longer than anything else since its tight to shaft and dirt can't get in there.Anybody drill the shaft for grease zert and ports to shock bushing? Mines not bent but the bushing and shaft are worn just as bad as the bent one in the picture.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
My sled has the cheap hpg shock in the center. I ordered replacement bushing from Yamaha and it's a plastic bushing.
Right. I said FOX spec. I will round one up and post pic. Guys the Qs3r has Cat springs on it and Cat spec parts. Such as this bushing. There is differences. Still a very good shock at heart.My sled has the cheap hpg shock in the center. I ordered replacement bushing from Yamaha and it's a plastic bushing.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
Ok, I should get the better bushing then.
Yes and steel shaft.Ok, I should get the better bushing then.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
2800 miles.
Shaft is worn and shock bushing.
New plastic Yamaha bushing and shaft.
WVTurboLTX
- Nov 9, 2014
- 2009 Nytro XTX
2017 Sidewinder LTX LE
So the 17 LE shocks are supposed to have a plastic bushing on that lower shaft?Right. I said FOX spec. I will round one up and post pic. Guys the Qs3r has Cat springs on it and Cat spec parts. Such as this bushing. There is differences. Still a very good shock at heart.
No. But better is available.So the 17 LE shocks are supposed to have a plastic bushing on that lower shaft?
WVTurboLTX
- Nov 9, 2014
- 2009 Nytro XTX
Gotcha. You had me worried I was missing something.No. But better is available.
I have some on order. They are Polyurethane. Like I said flexible. Some of the old Cat Act shocks had similar. Those would work in there also. One good thing about this Cat partnership. Is alot of possibilities if you look at both.
