**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
maybe take the rivet out closest to the heel along with the shims...too low of engagement i feel
Frozenstiff
- Dec 24, 2009
- Prescott, Ontario
- 2013 Arctic Cat Turbo
For normal trail riding, as long as it doesn,t bog on take-off, why not keep engagement as low as possible ?
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
agree** but If there's a impromptu line up....Id like it higher
Frozenstiff
- Dec 24, 2009
- Prescott, Ontario
Even then, I would think a little less initial power on take off to reduce track spin would be an advantage, as long as it doesn,t bog. I have done that for years, and it has worked great for me. I have found it kinda tough to hook up lots of power at the very start, especially with trail studs. For me, less initial track spin at the very bottom helps hook up quicker, once you are rolling.
Also works great when trying to load and unload sleds from the trailer.
Doowithblue
- Mar 17, 2016
- Waterloo ON
- 07 Mach z x (sold)
18- RTX LE
If you are like SJ and my sled, a little more won't hurt since we both have aggressive studding.
actionjack
- Apr 9, 2005
- Westminster, Maryland
- www.inspectorjack.com
- 2017 SideWinder LTX-LE
Which Ulmer clutch kit?I just got that same spring in with my clutch kit today from allen,along with a red secondary spring and 38 straight and new rollers,plus weights,oh ya sandale 3" flowmaster and alpha tubes and CAI oh ya evo stage 4 tune almost forgot.
kylechargerrt
- Dec 8, 2013
- Scotland Ontario
- 2017 YAMAHA SIDEWINDER LTX-LE
1998 MACH-Z
Just had a look of my oem spring that was pulled at 300 miles and there is all kinds of rust where the paint was rubbed off the outside of the coils. TP looks like new still. Not sure if the glide washers did the trick or the shorter length
Sent from my SM-G930W8 using Tapatalk
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
his stage 2 for 260 plus hp the loaded weight is 80.9 to 81 grams,black w/pink dot springs length is 3.550 thou long free length wire is .220 thou dia.. and a straight 38 helix with red secondary spring wire is .210 4 twists, opps spring has black paint on all 4 twists,and tangs line straight up to each other.Which Ulmer clutch kit?
Dieselxtx
- Feb 21, 2016
- Fox Lake, WI
- 2017 Sidewinder BTX LE
2012 Nytro XTX 1.75
Just looked at my primary spring after I lost 400 rpm and it was broke 2200miles it's going to the dealer tomorrow.
dgjr636
- Nov 16, 2013
- Clarence NY
- Sidewinder LTX LE
If looking to get back on the trail quickly and the dealer does not have one in stock or one they can steal. have them choose a alternate that is close. From what I have seen stock springs are on Back order and will not be available until a least the middle of March.
Dieselxtx
- Feb 21, 2016
- Fox Lake, WI
2012 Nytro XTX 1.75
Ok thanks my dealer sells clutch kits they put together themselves they should have something that will get me back on the snow! If they won't warranty it I may order a thunder products kit!
dgjr636
- Nov 16, 2013
- Clarence NY
- Sidewinder LTX LE
Good to hear. It's all about getting the seat/riding time in when you can in such a short season.
Best of luck!!
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
I have had great luck with the yellow/green/yellow Yamaha spring/with glide washers.. No rubbing, TD ECO tune and Td Turbo force muffler.. 911 clutch cover
dgjr636
- Nov 16, 2013
- Clarence NY
- Sidewinder LTX LE
Pics of collapsed clutch. Hope you can seen there is still space between the coils.
actionjack
- Apr 9, 2005
First thing that pops into my mind from looking at your photo is it hitting the cover? Maybe glide washers or those bearings are the only answer. As a dealer who is candid with us here what is Yamaha saying? The broken springs are adding up.
