So here are some pics of my Doo rail mounted scratchers on my Turbo Viper (129" skid). I got them mounted pretty far forward on the skid by moving my second set of outer idler wheels towards the back of the skid. The idlers are mounted in some stock holes at the back end of the rails and the scratchers do not come in contact with the upper idlers under full compression of the skid. Normally that second set of idlers are mounted on the inside of the rails. But because of the reservoir on my rear shock, they can't go on the inside. I ran these same scratchers on my son's Phazer last season, and they worked great.
Whats the cost on them?
Turtle
- Feb 27, 2006
- Marathon, WI
'07 FX Phazer GT
About $70 on Amazon ... part number SM-12542. I don't think these particular scratchers are offered by Doo anymore. They have been replaced in favor of the other rail mounted version noted earlier in this thread.Whats the cost on them?
Thank you Sir!About $70 on Amazon ... part number SM-12542. I don't think these particular scratchers are offered by Doo anymore. They have been replaced in favor of the other rail mounted version noted earlier in this thread.
Crossfire12
- Feb 13, 2017
- New York Adirondacks
- 2010 Z1 Turbo ,2017 zr9000, F1100 turbo, 700 srx
- Sacandaga reservoir
I had them the ones mounted to running boards, they worked great scratching but the spray missed my snow flap thus not working , if you have a long track maybe .the ones on the rails worked for me, just saying, check it.
putz21
- Apr 15, 2013
- Tomahawk, WI
- '25 Sidewinder XTX LE w/EPS
'23 Sidewinder LTX LE w/EPS
I will definetely be keeping an eye out for sure to see how they work on my 137. When you tried the tunnel ones, were they on a 129 or 137?
JayM
- Oct 29, 2018
- Pickering, ON
- 2017 Sidewinder R-TX SE
I wanted to add to this thread, I bought these for my 129" R-TX and used this to install. I realized in the first 5min that the hanger for the rear skid is much different in thr 129 vs the 137. The 129 it's much shorter making the spring needing to be right tucked to the running board so a small modification was needed to thr one end of the bushing. Still went on well. So much better than any other solution I have tried!
putz21
- Apr 15, 2013
- Tomahawk, WI
I love these ice scratchers. Very easy install and nice to just swing up and hang them on the hook when not needed. No worries about nicking up the rails like my rail ones did. Worked great all last year when I needed to use them. I really like the spring pressure they have when in the down position.
Yamatario
- Jan 8, 2009
- SW Ontario
- 2018 LTX SideWinder
2015 Viper LTX DX
2009 Nytro XTX
I have a new set on order with my dealer. He had just installed them on a new sidewinder. They are a cable style mounted on the A arm. As soon as they come in and I get them mounted, I will post pictures.
GR8BBQ
- Mar 23, 2018
- Hamlin, NY
- 2017 Yamaha SRViper X-TX SE
2017 Ski-Doo Blizzard 900 ACE
2001 Yamaha SXR 700 Triple
1995 Polaris Indy Lite
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
I just installed.these on my 998 should work well..imoI like these better from BRP but not sure where to get them or what the numbers are. They were at Novi on a show skid for Elka.
Yamatario
- Jan 8, 2009
- SW Ontario
2015 Viper LTX DX
2009 Nytro XTX
Yes, those are the ones. Can't see why they won't. You should be able to turn them more or less aggressive into the snow. Like the rubber hook-up to the side when you are not using them.Are they the Trail Blizzer from Qualipieces?
I saw them at the Big East Powersports show and liked the design. Wondering how they will work.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
Why do people drive down a snow covered trail with ice scratchers down?
They just spray snow everywhere and drive down the middle of the trail. My hyfax hold up just fine riding down the trail without them.
Ice scratchers are for ice!
Lower engine temp. Not all of us can be as perfect as you...LOL.. Merry Christmas
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
Merry Christmas to you also!
May your throttle be snappy and your roost be big!
WOW thats getting kind of personal.. its always big!! lol
