AndyApexLTX
- Jan 15, 2011
- Ottawa Ontario
- 2013 Vector LTX
Just finished installing a Camso Ice Attak XT (pre studded), 1.2 lug on a 2013 Vector LTX. The skid isn't installed yet, so the track is sitting on the drive sprockets only by weight, but I find the the web between the lugs, in line with the clips rubs against the front tunnel tubing, about 2mm 's worth
Anyone else install this track on a LTX and come across this problem, or is just because the skid isn't installed yet, to pull the track tight?
Thoughts.
Thanks.
Thoughts.
Thanks.
DGZRT
- Feb 23, 2006
- Stevens Point Wisconsin
Great question ! I'm leaning towards this as a replacement track for my Vector ! Hopefully some one knows the answer ...
AndyApexLTX
- Jan 15, 2011
- Ottawa Ontario
- 2013 Vector LTX
I have the question out to CAMSO Customer Service, but the sled track guy is out of the office until 15 May. I've asked if simply grinding away part of the web is an option.Great question ! I'm leaning towards this as a replacement track for my Vector ! Hopefully some one knows the answer ...
AndyApexLTX
- Jan 15, 2011
- Ottawa Ontario
- 2013 Vector LTX
Ok, no issue. Tonight I pulled the track tight and back with a strap, and the track clears the square tubing on the front heat exchanger.
AndyApexLTX
- Jan 15, 2011
- Ottawa Ontario
- 2013 Vector LTX
Based on how lugs are paddles, I think it will be a great track. the Camso rep replied, said he has ridden this track and it is great.Great question ! I'm leaning towards this as a replacement track for my Vector ! Hopefully some one knows the answer ...
DGZRT
- Feb 23, 2006
Have you added extra protection on the rear cooler tunnel protectors?? I 'm still running the stock Rip Saw with Bergstrom Trail Grabber Screw in studs. With the LTX model if you don't add extra depth it will hit the cooler. There is a write up on the main page for the RS Section of the forums . I found This out the hard way before I read it on this forum. The only good thing is the trail grabbers didn't cut through the cooler it only marked up the fins.
AndyApexLTX
- Jan 15, 2011
- Ottawa Ontario
- 2013 Vector LTX
I haven't, as the XT has a lug height of 1.2 compared to the stock 1.25 lug. With the picks I'm about the same height as 1.25.
I guess I'll see next winter, but I'm pretty confident that I should be ok as the Web will hit the tunnel protectors, the way the track is designed.
But thanks for the thought.
Farmer 73
- Feb 20, 2015
- 2010 NYTRO RTX SE, 2012 VECTOR, 2001 SXR 600, 2001 PHAZER, 2000 PHAZER, 1983 ENTICER EXCELL III
I put that track on my wife's 2012 Vector after 3000 miles no issues! It is a regular 121 Vector though.
- 24K
