RobX-1
- Coldwater, OH
If it looks fine I will bypass the tors by disconnecting the two bullet connectors and plugging them into their selves. If that doesn't work at least I know it's not the tors causing the issue.
That is how you're suppose to by-pass the tors; you have to connect the ends into themselves. Leaving them disconnected is not by-passing the tors.
