Clintww
- Mar 6, 2022
- Central MN
- 2001 SXR. 2005 RX1. 2017 Sidewinder
- MN
Just took advantage of your sale. Thank you!We have a sale going now through Sunday as well. Also if you enter SHIP23 when checking out it limits shipping to a flat $8 rate (USA only).
https://shop.ulmerracing.com/productlist.htm?browse=-73647&shopBy=-26776&catalogId=-11683
YamaSpark
- Sep 21, 2017
- Greenfield, Minnesota
- 2016 SR VIPER S-TX 137 DX
Darn, I should have waited. I paid $35 for shipping from PEFI! Oh well, it's only money....We have a sale going now through Sunday as well. Also if you enter SHIP23 when checking out it limits shipping to a flat $8 rate (USA only).
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
I'm going to have a fix for post wear. Had some sample bushings machined late last year and just now getting around to test fitting them. Should be around a $20 fix.
Pstn head
Are they on your website yet?I'm going to have a fix for post wear. Had some sample bushings machined late last year and just now getting around to test fitting them. Should be around a $20 fix.
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
2018 snoscoot
No, not yet. Making some changes to original prototype samples so don’t have them finalized yet.
Pstn head
K keep us posted…will need two, starting sled maintenance real soon…
Fleecer
- Jun 13, 2014
- 2019 SRX
It sure is pretty fits bang on.
The arm is well engineered, but is the skate better than a wheel? Wouldn't a wheel be less parasitic, albeit very slightly?
REDLINE 1
- Sep 20, 2019
- ROUND LAKE IL
- 2018 TCAT
I believe you can still run the wheel if you want. I have been running the skate with no issuesThe arm is well engineered, but is the skate better than a wheel? Wouldn't a wheel be less parasitic, albeit very slightly?
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
Actually the bend radius on the skate is actually smoother because the radius of the skate is larger than the wheel. There might be a little higher coefficient of friction, but not something I'd worry about on a trail sled.The arm is well engineered, but is the skate better than a wheel? Wouldn't a wheel be less parasitic, albeit very slightly?
You can not run the wheel, it will not fit the billet tensioner.I believe you can still run the wheel if you want. I have been running the skate with no issues
twyztid
- Feb 14, 2011
- Middleville, MI
- 2025 Sidewinder LTX LE EPS
2017 Sidewinder LTX SE
2012 Apex XTX
2012 RS Vector LTX
- Middleville, MI
I installed the PEFI skate in my 2017 before this past season and it is a very nicely built piece.Actually the bend radius on the skate is actually smoother because the radius of the skate is larger than the wheel. There might be a little higher coefficient of friction, but not something I'd worry about on a trail sled.
REDLINE 1
- Sep 20, 2019
- ROUND LAKE IL
- 2018 TCAT
I contacted pefi out of curiosity. They confirmed that you can use the roller wheel with there HD tensioner. When you purchase the arm you have the option of buying it with or without the skateActually the bend radius on the skate is actually smoother because the radius of the skate is larger than the wheel. There might be a little higher coefficient of friction, but not something I'd worry about on a trail sled.
- Apr 17, 2003
- Menno, SD
- Menno, SD
I’m only telling you what I have firsthand experience with. The stock roller will not fit into the billet tensioner. It bottoms out before you can line the pin up with the hole.I contacted pefi out of curiosity. They confirmed that you can use the roller wheel with there HD tensioner. When you purchase the arm you have the option of buying it with or without the skate
REDLINE 1
- Sep 20, 2019
- ROUND LAKE IL
- 2018 TCAT
Interesting. I wonder if there are different sizes on the wheels?I’m only telling you what I have firsthand experience with. The stock roller will not fit into the billet tensioner. It bottoms out before you can line the pin up with the hole.
twyztid
- Feb 14, 2011
- Middleville, MI
2012 Apex XTX
2012 RS Vector LTX
- Middleville, MI
Is there a reason that you seem to want to run the wheel? The skate works, and as stated above, puts less radius on the chain.Interesting. I wonder if there are different sizes on the wheels?
REDLINE 1
- Sep 20, 2019
- ROUND LAKE IL
- 2018 TCAT
Not me Been running the skate with no problemsIs there a reason that you seem to want to run the wheel? The skate works, and as stated above, puts less radius on the chain.
Someone else was asking which was better and I thought they were interchangeable on that tensioner when they aren’t despite what the manufacturer says lol
- Sticky
- 93K
- 29K
