snolover
- Dec 1, 2004
Allen ,how much for shipping charge in CANADA , also do i need a longer belt to get more speed
Thanks.
Thanks.
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
Shipping charge will be slightly dependant on location and also on how you want it shipped. The cheapest will probably be USPS Air Mail and be $18-20. This uses the stock 8DN belt.
stoutner
Allen,
Do you have a "spare" clutch that is machined? That would be sweet! Then, You could ship it to me and I could ship you mine...as a "core". If not, maybe I'll send mine to you after asphalt is over.
- Apr 17, 2003
- Menno, SD
- Menno, SD
Wayne, I do not currently have any clutches pre-cut at this time.
minks_698
- Dec 21, 2006
- Wisconsin Rapids
- 2016 Viper MTX 141
Allan, would you still recommend gearing up an 08 Nytro even with the clutches cut to shift all the way out?
- Apr 17, 2003
- Menno, SD
- Menno, SD
Probably no need to gear up the FX Nytro with clutches cut. If you gear up I would probably just switch to a 38 bottom tooth instead of the 39 that is stock.
BADSLED
- May 13, 2004
- Syracuse, NY
- 2012 Nytro MC Xpress 270
2011 Apex SE
2021 Sidewinder LTX SE - SOLD
Allen,
How does machining the Primary Clutch for overdrive and decreasing the belt clearance affect tuning the Super Tips? How would you re-configure the weight placement?
- Apr 17, 2003
- Menno, SD
- Menno, SD
I haven't done a ton of testing with that setup (cut clutch & super tips) simply due to the fact that we don't cut very many primary clutches (maybe 10 in the last 4 years). I will try to dig through some notes and see if I can find that information!
