viperrtx
- Dec 21, 2014
- yamaha viper rtx
About to order the parts for the cotc quick question though I see that it gives smooth engagement and better top end. My question is will I lose low end torque though?
- Apr 14, 2003
- Hessel, Michigan
No, that is the one thing that the 8FP weights do is make it pull like hard on low end and mid range and still have good top end
I know there are a lot of posts here, but I see all that have tried the setup love the low engagement and pull on bottom end. I will let them reply
Blue Dave
- Jan 7, 2008
- Ham Lake, MN
- '17 Sidewinder LTX DX
In my experience I seemed to gain everywhere. It pulls really hard from launch straight through to 100 mph.
benjamingvsu
- Oct 9, 2007
- Stevensville, Michigan
- 2014 Viper rtx se
Well, I almost got mine dialed in. I've got about 800 miles on it.
14 rtx unstudded, 8dn belt
8fp weights, 4.5 in tip, 2.44 in center
Gwg spring with 4 shims
46/40 helix
Wrap is at 6-1
Awesome everywhere, but max speed is 97, banging the rev limiter somewhere above 90.
Do you think 3-3 will get me off the limiter, or should I throw 1 or 2 more grams at the weights?
46/40 helix
Wrap is at 6-1
shagman
Vendor
- Feb 18, 2014
- Cedarville Michigan
- 2017 Sidewinder BTX LE
2014 SR Viper XTX SE (Sold)
Remove 2 shims. You need more belt grab at wot.
stingray719
46/40 helix
Wrap is at 6-1
If you don't need much the 3-3 wrap may do it and as that is a quick and easy change I would try that first.
viperrtx
- Dec 21, 2014
- yamaha viper rtx
Just bought a 4 mm Shim to try out the stage one for my stock Yamaha Viper what can I expect to see different out of curiosity with just the shim.
stingray719
Slight raise in clutch engagement and more power throughout the range.
viperrtx
- Dec 21, 2014
- yamaha viper rtx
Will the slight raise cause it to creep forward smoother?Slight raise in clutch engagement and more power throughout the range.
stingray719
The stock 8GL weights have a raised bump on the heel that causes higher revs at take off. The shim will raise the take off rpm a little and make that worse so if slow take off is what you are after do not shim it, but put the full COTC in it and then it will creep along with a very low engagement.
If you don't wish to do a lot of changing Barn Of Parts vendor on here has the "Soft Touch" primary spring that will lower your engagement speed a lot. And if I remember right it is only a 26 dollar spring.
viperrtx
- Dec 21, 2014
- yamaha viper rtx
Thanks. Now idk what to do with the shimThe stock 8GL weights have a raised bump on the heel that causes higher revs at take off. The shim will raise the take off rpm a little and make that worse so if slow take off is what you are after do not shim it, but put the full COTC in it and then it will creep along with a very low engagement.
stingray719
Its quick and easy to put in try it and see.
viperrtx
- Dec 21, 2014
- yamaha viper rtx
Could you link me to the barn of parts guy I can't seem to find him on this website under the vendors thanksIts quick and easy to put in try it and see.
stingray719
Sure thing, http://www.barnofparts.com/Soft-Start-Clutching-NEW-.html
I run that spring in both my Vipers now, might drop a small amount of speed but the ultra smooth takeoff is worth it to me.
viperrtx
- Dec 21, 2014
- yamaha viper rtx
Thank you very much. You helped out a lot. Quick question does this spring ruin the low end speed if I wide open throttle it. Or is it pretty close to stock for power when wanted?Sure thing, http://www.barnofparts.com/Soft-Start-Clutching-NEW-.html
