stingray719
Thank you very much. You helped out a lot. Quick question does this spring ruin the low end speed if I wide open throttle it. Or is it pretty close to stock for power when wanted?
The power loss if any was not noticeable by the butt dyno.
phazerdrew
Just did clutching on the cheap and have noticed no real difference over stock, 14 xtx stock no mods
Gwg primary w/ 1 shim on sheave side, engage seems to be at 3800 very hard to tell tho, 3800-4200 is when the sled begins to move
8fp w/ 3.6 rivet
8dn
46/40 helix 6-1 wrap
Osp belt adjuster
Still hitting over 8k between 60-70 mph, looking to lose 500-1000 rpm to gain fuel mileage, ran about 35-40miles tonight to test it
8fp w/ 3.6 rivet
8dn
Osp belt adjuster
yamaha06
Quick question for you guys. I have the COTC installed in my sled and notice a big difference compared to stock. Sometimes when I am flying through the tight windy trails I will be on the flipper pretty hard then have to slow down quick and the clutch makes a noise like its popping the belt up out of the sheaves makes a little weird noise then when I give it gas you can feel it grab the belt hard sled kind of jerks forward and were off again. Anyone else have this?
stingray719
8fp w/ 3.6 rivet
8dn
Osp belt adjuster
How many miles on the sled please? Can you remove the belt and primary clutch cap and move the outer sheave in and out to see if it freely moves all the way in and out?
stingray719
Can you look at the end caps on the rail please and see if there are any wear marks above where the track contacts?
phazerdrew
2000 miles, when I changed the weights I checked this, seems to move freely no stickingHow many miles on the sled please? Can you remove the belt and primary clutch cap and move the outer sheave in and out to see if it freely moves all the way in and out?
- Apr 14, 2003
- Hessel, Michigan
8fp w/ 3.6 rivet
8dn
Osp belt adjuster
Yeah, something not right there...
Do you have the LE with the low gearing?
phazerdrew
I don't believe I do, it only has the 1.6 lug track not the big 2.25
stingray719
See if your rail caps look like this,
stingray719
8fp w/ 3.6 rivet
8dn
Osp belt adjuster
As NOS-PRO said something is wrong if you have 8FP weights and 3.6 rivet and engage at 3800. Also what is your target rpm at full throttle I was a little unclear on that.
yamaha06
Alright I will have a look at mine. If mine are like that can it be causing my problem? What causes this to happen and how can it be fixed?
stingray719
Its not in your signature, what Viper model do you have?
yamaha06
Sorry, 2015 ltx se
stingray719
Sorry, 2015 ltx se
With limiter straps tighter than mine (almost all trail sleds do) you may not see this, but if you do put anti stab kit on right away.
The track stabbing is going to have to be watched. I also run my limiters all the way out. Stock Position. Buddy with a 13 SnoPro Turbo Cat does same. Was fine till 5500mi then his shock pulled right apart. His straps had stretched allowing the shock to be limiting factor for downtravel. That is bad and will ruin a shock quick. Straps look fine. With suspension hanging and straps in the longest position the bolts should not go in shock freely. The shock should need to be compressed 1/4in or so before last bolt slides in. This puts the force on straps where it belongs not shock.
