Alsim
- Oct 6, 2014
- LTX SE 2018
Hi!
Report of my last trial today with 4.5 in the tip, 3.6 in middle wrap at 6-1 Dalton 45/39 and 4 shims .
I Hit the rev limiter (9281) speed was 93 mph in about 1500 ' . It's seems lot a spin at hole shot. I prefered 3-3 wrap. Next try I will remove 2 shims and 3-3 wrap and I think I will be on the spot !
I tested this set up saturday . I raced one mack z 1000 and one z1 turbo. I had amazing hole shot with about 4 length on each sled but they catched me at about 1500 feets. I reached 85 mph on loose snow and belt did 1/4 inches near the top of the clutch
Alsim
- Oct 6, 2014
- LTX SE 2018
I need to full my clutch for more mph after 1000 feets . May be I will remove one shim to have more grab on belt
Alsim
- Oct 6, 2014
- LTX SE 2018
http://media.anjou-connectique.com/...5/b/o/bobine-fil-brasure-etain-cuivre2502.jpg
Or 1 -2 grams in the tip with this stuff
- Apr 14, 2003
- Hessel, Michigan
Your getting close Alsim!
Nice to hear about the holeshots!!!
Alsim
- Oct 6, 2014
- LTX SE 2018
Thanks Terry !
If I want to keep my holeshots and increase my top speed, do I have to remove 1 shim or increase weight in the tip? The belt stop at 1/4 of the top primary and the rpm is near 9160
Sam Zuehlke
- Jan 26, 2015
- Central Wisconsin
- 15 ltx le viper
- CTL WI
Has anyone tried 8fa weights in the COTC . If so what were they loaded with? Had a friend give them to me to try on the viper.
stingray719
Less shims hurt low and midrange but usually help top.
stingray719
Clamping profile looks like the 8FS I would say try them and let us know. But at 64 grams and only two holes for rivets you might have to put 4.5 in tip and 3.6 in base.
Sam Zuehlke
- Jan 26, 2015
- Central Wisconsin
- 15 ltx le viper
- CTL WI
I will try them with that rivit setup and report back to you guys. Thank you for all your help.
Sam Zuehlke
- Jan 26, 2015
- Central Wisconsin
- 15 ltx le viper
- CTL WI
A quick question that I forgot before I posted. Has anyone tried different rollers? He also gave me 15.6 rollers. What does stock clutch come with?
stingray719
Rollers change the belt clamping force, and a few other things. I would go with the weights first as rollers would skew the results you are looking for.
- Apr 14, 2003
- Hessel, Michigan
Thanks Terry !
I would look at adding weight to the tip....try to find a happy -medium.
stingray719
x2
Alsim
- Oct 6, 2014
- LTX SE 2018
.5 gr on each weight will decrease 1500 rpm right ?
stingray719
No, it is roughly 1 gram for each 200 RPM. So putting a 1 gram weight in all 3 weights should lower you approximately 200 RPM. That is just a rule of thumb though and not an exact science.
