![](/styles/TYLifeMember.gif)
![](/styles/vip.gif)
I put it all in the first post first page. I couldnt seem to get the pics to show but the links take you to the pics. Let me know if this is alright with you guys.do you mean start a new thread?
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
stingray719
Thanks! I fixed it but there is a 10 pic limit on the posts so two pics are still links.
Jeepjklabrador
- Jan 14, 2015
- 2015 sr viper mtx
2014m8000
2012 skandic swt
So i finally decided to try this "clutching on the cheap" and my reaction is WOW i always thought that the stock clutching on my machines were "good enough " but when i got this viper i was highly disappointed in the mid / top end mine is a mtx, stock it was all bottom end grunt but past 30mph lazy was not what i expected from the 1049 nor what i had experienced from nytros i drove ,talking with stingray he has helped me tremendously getting my viper where i want it to be . I got everything i needed locally i had the fab shop i work at make shims , got a helix for $50, Weights for $30 and a new g/w/g spring for $30 all i needed for $110 Canadian my viper now pulls and performs way better then it did and for the first time today i really enjoyed squeezing that flipper
cant wait for the airbox mod![Rockon :Rockon: :Rockon:](/styles/default/xenforo/smilies/rockon.gif)
Stingray you sir are the man i cannot express my gratitude enough i now love my sled ![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
stingray719
So i finally decided to try this "clutching on the cheap" and my reaction is WOW i always thought that the stock clutching on my machines were "good enough " but when i got this viper i was highly disappointed in the mid / top end mine is a mtx, stock it was all bottom end grunt but past 30mph lazy was not what i expected from the 1049 nor what i had experienced from nytros i drove ,talking with stingray he has helped me tremendously getting my viper where i want it to be . I got everything i needed locally i had the fab shop i work at make shims , got a helix for $50, Weights for $30 and a new g/w/g spring for $30 all i needed for $110 Canadian my viper now pulls and performs way better then it did and for the first time today i really enjoyed squeezing that flippercant wait for the airbox mod
Now lets get that air box mod on and kick some butt in Cains Quest!
niarve00
- Jul 15, 2013
I have XTX 2014 with COTC. 4mm shims, stock helix, 6-1 wrap. Usually it´s working fine but problem is that if I get stuck it burns belt very easily:/ Same happened with stock clucthing. What can be problem?
stingray719
Are you running the stock belt or 8dn?
Jeepjklabrador
- Jan 14, 2015
- 2015 sr viper mtx
2014m8000
2012 skandic swt
I have the same problem ...had it stock as well with both belts
niarve00
- Jul 15, 2013
I have the same
stingray719
These tunnels pack a lot of snow in the front when going through deep snow. When stuck I put mine in reverse and hit the throttle one time to turn the track about half a revolution or so backwards (not enough to stick it worse) then hit it forward.
RTX
- Mar 31, 2005
- massachusetts / maine
- 2014 viper rtx
2006 apex rtx
Have been running the cotc set up all season
1700 miles on the sled
Set up is 2 shims in primary
8fp weight with 3.2 rivets
Gwg spring
46/40 helix set @ 6-1 shimmed .060 with stock secondary spring.
Right now im hitting the revlimiter on wide open pulls/top speed runs.
I am planning on installing either the turbo dynamics, sandale, or EVO muffler over the summer.
Obviously i need to add more weight but how much?
I was thinking about installing the 3.6 rivets in the tip but i was thinking the addition of the exhaust might require more weight than that.
Do you guys think i would be better off using the 4.5 rivets?
Any help is appreciated.
Gwg spring
stingray719
Gwg spring
4.5 with aftermarket muffler should be very close.
- Apr 14, 2003
- Hessel, Michigan
Gwg spring
Just like Stingray has mentioned....you going to the 4.5 rivets will be real close if not spot on with an aftermarket can.
benjamingvsu
- Oct 9, 2007
- Stevensville, Michigan
- 2014 Viper rtx se
Thanks for the pics Yamamarc - I just noticed you put the primary shims in the cover - I actually put mine on the other end of the spring - does anyone think it matters?
I went ahead and bought the MPI rivets and put them in the tip - pricey, but hopefully gets my RPMs down enough up top.
I'm breaking rule #1 of clutch tuning and changing more than one thing at a time - I'm moving back to 4 shims, and I'm trying the soft start primary spring from Barn of Parts. I got tired of leaving rubber on the concrete when moving the sled around the garage, and I also noticed I spun the track going into my enclosed trailer. On the stand and moving the sled around the garage the engagement is definitely lower - I can move it now without spinning the track. Hopefully this set up works on the snow too!
stingray719
Sounds great, I agree with what you are doing the soft touch spring rocks.
