The D&D is flatter except at heel. But man that 8fp is beefy at end! Look where most of my wieght ended up. Tip holes are full.
Studroes144
- Oct 30, 2013
Is this 1-0-3-3 or 2-0-3-3?
2-0-3-3
Studroes144
- Oct 30, 2013
2-0-3-3
63.4 grams, you're making real good power to be throwing weight like that with such aggressive weights, your hard work and mods has certainly paid off.
That's with the 25-45 gearing. Bit low. 9050 last ride. Clutches nowhere near maxed. Was at 9100 with 2-1-3-3 and stock gearing clutches both maxed. Still need a bit more. But thanks. Those weights really allowed me to try different things without spending hrs tuning clutching. I will never run anything other than magnets ever again.Never would have tried them if you wouldn't have sent them. Now will try the OSP and see63.4 grams, you're making real good power to be throwing weight like that with such aggressive weights, your hard work and mods has certainly paid off.
Byam
- Apr 23, 2015
- En Motoneige
- SW2017
custom
Hi guys. Me i use the Gforce magnetic Vt-5 ,so simple to work ! 2 different magnet Weight
I have two primary in stock, i will try one COTC but i am gona machined the 8FP weight to make the magnet fit in
View media item 805
stingray719
I have two primary in stock, i will try one COTC but i am gona machined the 8FP weight to make the magnet fit inView media item 805
I tried to drill an 8FP weight and smoked two drill bits and didn't do much. Anybody have an idea for a drill bit strong enough to drill these?
Carbide but would it be enough weight?I tried to drill an 8FP weight and smoked two drill bits and didn't do much. Anybody have an idea for a drill bit strong enough to drill these?
stingray719
Original post edited to reflect shims from Thunder Products and Barn Of Parts spring
stingray719
After much testing I now prefer the "Soft Touch Spring" from Barn Of Parts to the Green/white/green. The soft touch seems to have the same finishing rate but the take off is MUCH smoother and less track spin. He may also have some used 8FP weights for sale. http://www.barnofparts.com/Soft-Start-Clutching.html
Nothing wrong with GWG I just like the lower engagement for soft snow.
fiddlersgreen
- Feb 19, 2009
- Newfoundland...The Rock
- Viper xtx le
Oh well........
8fp's available just after I ordered the thunder products kit today...lol!!!
Steve Wright
- Oct 17, 2014
- Omemee
- 2014 Yamaha SRViper L-TX SE
Will the clutch weights work with the evo reflash? or are they not heavy enough now? I'm sure weight has to be added but not sure if enough can be added to the tip after the reflash.
stingray719
I have a set of 8FP sitting on my desk that are 78 grams with regular rivets that came out of an Apex so yeah I think you can get enough weight
I think Tim managed to get 85 grams in a set of 8fp.
rbell14
Stingray, you prefer the soft spring from BOP over the spring in the Big Venom kit from Thunder Products or are those pretty close in performance?
stingray719
I prefer the soft touch spring over everything I have tried. 4 stroke torque engine needs soft take off spring to minimize track spin in my opinion.
