polarcat71
history first,
bought a sled (btx-se 153" 1.75") used this year (and original owner has no idea what was in it, had someone else do the work to it)
he had hurricane stock muffler tunes in it (up to 270), it now has the 3 bar sensor, hurricane quite performance muffler, super spool tunes (240,270, 300) and I geared it with 22/36.
no trying to tune the clutching but want need starting point
can not find the following information
primary has a Black with a gold line and a red dot (what is this spring and whos is it?? rates?) can not find info anywhere
secondary has
black yellow (again I don't know if that is stock one from Yamaha or after market) what is it and whos? rates?
helix is 8KC50 it stock one is this a 50deg straight ramp?
I also put in the dtya-1 Dalton weights
engagement is low like 2400-2500 and top rpms are low as well (even in 300 tune) pulling like 8600 rpmson long pull
secondary has
TPAY243
- Apr 14, 2013
- Northern Wis
- 2020 Yamaha Sidewinder LTX SE
If you just up graded to a Hurricane muffler tune the best thing to do would be to call Dave at Hurricane and ask him what you should have in it for clutching. You are gonna get a bunch of suggestions from this site and unless you have some clutching experience and a whole bunch of parts you will be chasing your tail. Just call Hurricane and get what you need and be done with it.
Crossfire12
- Feb 13, 2017
- New York Adirondacks
- Sacandaga reservoir
Second that!
Primary spring appears to be gold-red-gold which is stock.
Secondary spring stock.
Are the weights empty?
Rollers OK?
What belt?
It should pull those weights empty.
Rollers OK?
What belt?
STAIN
- Feb 29, 2004
- Vermont
- 2022 SIDEWINDER LTX GT
- Vermont
That is some tall gearing.
TPAY243
- Apr 14, 2013
- Northern Wis
I agree STAIN I realise it a BTX with 1.750 track but that's pretty tall. What do they come with stock and what size drivers.
STAIN
- Feb 29, 2004
- Vermont
- Vermont
That thing is geared for 154mph!!! That is is with the 3.0 pitch track. My RTX is geared for 123mph with 300 hp.
I think they have one size smaller drivers
STAIN
- Feb 29, 2004
- Vermont
- Vermont
8 tooth=137
7 tooth=120
7 tooth=120
An 18 BTX parts break down shows a 50 bottom gear.
You have the Daltons already, so you just need to figure out what gearing you want and adjust weights accordingly which may include lightening them.
polarcat71
It’s geared for 122mph (no overdrive)An 18 BTX parts break down shows a 50 bottom gear.
I will def play with the weights
Just wanted to know what the rates of the springs that are in there are so I could get a couple to try at higher rates (I think I figured out the primary it’s not black gold red it maybe black bronze dalton (bronze, gold who can tell diff in a dot! And the red dot maybe something the installer mark on it who knows!)
Is the stock helix a straight 50deg?
justinator
stock helix on an 18 winder is straight 35 degree.
TPAY243
- Apr 14, 2013
- Northern Wis
Is 122 mph feasible with that 153 1.750 track that's a lot of churing and burning going on.
DooZ
I agree, that's alot of gear for that much track. What are you trying to do with the sled, lake race, off trail, etc? IMO you're gonna have a heck of time clutching that thing, and keeping belts on it.Is 122 mph feasible with that 153 1.750 track that's a lot of churing and burning going on.
Crossfire12
- Feb 13, 2017
No
