yammitrip1
- Sep 28, 2017
- Rome ny
- back country sx viper, trail sx viper s
Just get it running and ride it. All years of four-stroke, all manufacturers have had problems starting in severe cold temps. I've seen it all. I've seen 2 strokes not start in that temp.
savageman69
- Apr 21, 2014
- 2014 arctic cat zr 7000 limited
Yah the battery has been on the back of the procross since 2012...never seemed to bother the suzukis.....i think its mapping or intake design
Alsim
- Oct 6, 2014
- LTX SE 2018
I heard the RED relay is a good way to go. Someone know where I can buy it ? Number of part and brand ?
grizztracks
TY Advertiser
- Feb 24, 2005
- Scio, NY
No red solid state relay available for these Arctic Cat electronics and probably never will be.
Alsim
- Oct 6, 2014
- LTX SE 2018
Zut! Thanks Grizz !No red solid state relay available for these Arctic Cat electronics and probably never will be.
chuckpp
- Mar 27, 2013
- Belmont N.H
- 2016 Yamaha srviper ltx dx
You can get the red relay for the vector its a solid state.My friends vector was outside and it would not go either.his cat and nytro fired up but they were in his shop.got mine in the shop now and see if it will start tomorrow morning.if it doesn't start. back to the dealer.
yammitrip1
- Sep 28, 2017
- Rome ny
I have seen lots of 4 stroke yamaha's ( apex, vector, nytro and phazer), and 4 stroke cats (t660, 1100) bombardier 1200 and Polaris fst not start during extreme cold temps.
Too much that could be at fault. Battery strength, starter strength, oil viscosity.
savageman69
- Apr 21, 2014
yes like i said i dont think battery location is the issue.I have seen lots of 4 stroke yamaha's ( apex, vector, nytro and phazer), and 4 stroke cats (t660, 1100) bombardier 1200 and Polaris fst not start during extreme cold temps.
yammitrip1
- Sep 28, 2017
- Rome ny
My bad, I interpreted that wrong. Cheers!yes like i said i dont think battery location is the issue.
rebmo
- Mar 8, 2014
- Rural SE Wisconsin
- 2015 Yamaha RTX-DX blk
2015 Arctic Cat XF 9000 Green (Turbo)
Up in Calumet U.P. this week. As low as -7F and the viper has been starting fine. Original 2015 battery (actually the original one failed right away, and warranty replaced when new). My 15 CAT Turbo fired up right away too. Most starts on first turn over, once the Viper took too tries. The only Viper fail we had was reverse didn't work at first. Backed off the trailer fine, but then no reverse. Heard a click and the beeper was going, but still in forward. After it warmed up reverse was fine. Fine the day after too. May have been a cold relay. Viper running great in this cold weather so far. I know when the first battery went bad when new it showed good voltage and took a charge, but my battery charger indicated a fault. It would crank but not fire. As soon as I got the replacement battery if fired right away. These sleds seem very particular about full battery charge.
Carla 123
- Feb 27, 2017
- Manitoba
- 2015 viper xtx boosted
17 zr9000 precision stage 3
Mine will start jut fine at -7.its when it's-25 and colder it won't goUp in Calumet U.P. this week. As low as -7 and the viper has been starting fine. Original 2015 battery (actually the original one failed right away, and warranty replaced when new). My 15 CAT Turbo fired up right away too. Most starts on first turn over, once the Viper took too tries. The only Viper fail we had was reverse didn't work at first. Backed off the trailer fine, but then no reverse. Heard a click and the beeper was going, but still in forward. After it warmed up reverse was fine. Fine the day after too. May have been a cold relay. Viper running great in this cold weather so far. I know when the first battery went bad when new it showed good voltage and took a charge, but my battery charger indicated a fault. It would crank but not fire. As soon as I got the replacement battery if fired right away. These sleds seem very particular about full battery charge.
Agreed. -10 -15 I've never had an issue with the 4-strokes starting that I've owned. If those temps were a regular issue to get it started, I wouldn't own the sled.
hellflyer
- Dec 2, 2008
- Georgtown ONT. Canada
- 2020 sidewinder ltx se
Funny! Mine withe new flash took at least three tries to start last year when really cold. This year on a hunch I leaned the pcv a couple points below 2000rpm and it's been starting regularly in one try, yesterday morning it fired up first try at coolant temp - 28c my buddy's nytro next to it 3 attempts and not good ones. I think the new flash is very rich at crank speed.
Alsim
- Oct 6, 2014
- LTX SE 2018
Surely they richen up with the new flash to eliminate the kick back and starter issue.Funny! Mine withe new flash took at least three tries to start last year when really cold. This year on a hunch I leaned the pcv a couple points below 2000rpm and it's been starting regularly in one try, yesterday morning it fired up first try at coolant temp - 28c my buddy's nytro next to it 3 attempts and not good ones. I think the new flash is very rich at crank speed.
grizztracks
TY Advertiser
- Feb 24, 2005
- Scio, NY
How does a richer A/F mixer eliminate kick back? The new flash may have made a slight change in fuel mixture but there was more to it than that.
