Nitroya
- Nov 12, 2012
I m currently attempting to remove the Drive shaft bearing, I ve removed clutch, speed sensor, bottom sheet metal guard, and the set screw on inside tunnel. This is where I am now and cannot remove bearing yet. Those the chain case half to be opened up to push shaft out??... Is there a way to do without going in chain case. Sled as 6000 miles and bearing was a little rusty inside.
There are 2 set screws on the bearing your try to remove which have torx heads, take a good light and take a look from the bottom between the sheet metal gaurd and the bearing, loosen em up and it should pull off.
sorenson1610
- Dec 11, 2007
- Rothschild,WI
- www.contrx.com
Yeah remove those 2 torxs and it should come out without problems. Pretty simple and easy to avoid breaking down trail side. Might have to give it a whack to brake it loose if it's rusty.
nytroxtx17
- Sep 11, 2010
- Barrie, Ontario
- 2018 Sidewinder LTX SE
I just did mine today. A piece of advice for all, you need to remove the splined end of the driveshaft that the speed sensor reads. I used a 3 jaw puller to pull the bearing through and it wouldn't go through the splined end. The old bearing is stuck on this small splined shaft now.
Alphadog
- Mar 6, 2015
- Appin Ontario
- 2018 Sidewinder
Just did mine as well once the set screws out the bearing popped right off replaced it with the new one, buttoned her back together and ready to rock just need some dam snow here to test drive before we do the RAP in Feb.
- 14K
- 40K
