Moodeyblue
- Sep 16, 2003
- Alberta
- Sidewinder SE
Have any of the aftermarket guys done an ECU reflash with stock the muffler. I understand it is restrictive but what are the gains for this...if any.
Personally, I think this machine goes fast enough for me, but I want to drag it 660 ft, and only a reflash is allowed.
- Sauk Prairie, WI
- www.ty4stroke.com
If your not looking for giant gains, maybe consider the mod stock exhaust upgrade. You send your stock exhaust in, they essentially gut it and add more flow. I have seen some dyno numbers with this mod alone and they are around 220 HP. Beauty here is you don't need a flash at all.
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
I'll be doing some testing shortly with a modified stock muffler & a Evo tune that will run 12.5 lbs of boost.
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
Ya,but by the time someone mods the stock can,you may have al most as much money invested it it,andnow cant put it back to stock if wanted to sell later on.
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
Allen will your tunes also work on an osp or hindle muffler?
Or you can run any tune with stock exhaust but it's very risky since builds heat fast.
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
Hi cannondale are you still working on rebuilding shocks,i have one that broke the shaft in half,not sure if the bottle is still ok or not,sled is at dealers now,but if you want or can rebuild it,i will have him send it to me,so I can send it to you,its off the sw 2017 ltx-le qs3 front shock. peteOr you can run any tune with stock exhaust but it's very risky since builds heat fast.
PM'ed youHi cannondale are you still working on rebuilding shocks,i have one that broke the shaft in half,not sure if the bottle is still ok or not,sled is at dealers now,but if you want or can rebuild it,i will have him send it to me,so I can send it to you,its off the sw 2017 ltx-le qs3 front shock. pete
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
who is doing this mod and how much do they want?If your not looking for giant gains, maybe consider the mod stock exhaust upgrade. You send your stock exhaust in, they essentially gut it and add more flow. I have seen some dyno numbers with this mod alone and they are around 220 HP. Beauty here is you don't need a flash at all.
- Sauk Prairie, WI
- www.ty4stroke.com
Turbo Dynamics and D&D are doing it. Not sure how much, but should be on there websites.who is doing this mod and how much do they want?
Ulmer did my Viper Stock can and it sounds great. Have not tested yet. Anyway he is looking for someone with Sidewinder to do this to also. May have found someone by now but worth a call. I would think first guy gets a big discount.who is doing this mod and how much do they want?
- 14K
