snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
Thank you,that is great info,why in GODS name would Yamaha say not covered,its there brand new clutch set up,are they trying to pull a fast one,and I am trying to get them to replace my parts for a crashed sled?Is there others whit that issue.mine have 200km and have a flat spot on a roller.yamaha say not cover.and back order for at least 3 weeks.i just saisd forget it and get 3 rollers from a 2015 cat driven and it fit there and work good so,have to let you know if you're in the same boat.the rollers have the same over all diameter,width,and center hole too.
stone88
Well put 50 miles on the new rollers took the helix out and they still look perfect. Will know more next week going on a trip and will put a bunch more miles on and I will see what happens.View attachment 124343 I hope this is the answer out testing now.
done dooin'_winder up
- Dec 6, 2016
- saegertown pa
- 2017 sidewinder stx 137 dx
i got it when you said it. appreciate it. i went right over and read on the 850. what i meant is that they don't read forums so they won't see the blue bashing over there or even know whats going on with their 850s, so if i read em i can let them know when they start seeing problems that they aren't alone. in a nice way of course. not like "i told ya so". i don't regret my decision in the least, just lettin others know that i see the same things as they do with the winder. its all good. minor annoyances. glad folks are pointing them out to keep breakdowns to an isolated few. hopefully yamaha reads too. i hope this is at least a 20-30k mile sled. are those rollers replaceable without pulling the clutch? the primary rollers were worn to brass? in spots, is that normal? are they gonna last? not a clutch guy...thanksMaybe I wasn't clear. All those things I listed are 850 issues.
If Yamaha has a flat spot on one bushing, "the clutches are junk!" They all grab their spears and start chanting!
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
theres two versions of the same part number...what did you use jon and ernie....regular or torlon?
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
Torlon. I used the ones I had a link to on this post. Got them today. Going on a week trip to cabin in the UP. Should have a good idea if they are good or not. Here you go SJtheres two versions of the same part number...what did you use jon and ernie....regular or torlon?
jpr-ltx-dx 2015
- Sep 21, 2014
- sr viper ltx dx
went out today for 100mls run whit cat rollers and they run perfect,now ,going to give a try to dalton ramps.
iceback
So what are white cat rollers ?
iceback
Sorry read with cat rollers
SaskAttack
- Jan 4, 2006
- Corning,SK.
- 17 Sidewinder XTX-SE
- Corning, SK. Canada
Jt, if They all grab their spears and start chanting! then we will just run them out of the interwebs with our torches and pitchforks!
Joe ltx-le
- Mar 26, 2015
- Beaverbank-ns
- 2017 sidewinder ltx-dx
I've got my torche lit. 2 strokes light up easy.Jt, if They all grab their spears and start chanting! then we will just run them out of the interwebs with our torches and pitchforks!
Joe ltx-le
- Mar 26, 2015
- Beaverbank-ns
This seems to be the number one issue with SW.
It's gotta be material issue if the cat rollers last.
Come on Yamaha ! Catch up and fix this !
Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
Hahaha!!!!! We know they can't outrun us.
Doc Harley
- Oct 17, 2016
- Here & there
I checked my low milage unit. Rollers show no signs of flat spots.
Thanks again........ Joe
vodoo child
- Oct 29, 2005
- Palmerton Pa.
- 2018 Sidewinder LTX/LE 50th
Looks like the Lenco roller cover I had on my ZRT8 back in the day. 8k+ miles on that cover and zero issues. The rollers in that cover were super hard and had a needle bearing on the pin. Firm believer in the bearing and pin setup over simply letting the roller revolve around the pin.Here is your solution....View attachment 124332
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Some of the best clutching from CAT was that three roller cover on the secondary!Looks like the Lenco roller cover I had on my ZRT8 back in the day. 8k+ miles on that cover and zero issues. The rollers in that cover were super hard and had a needle bearing on the pin. Firm believer in the bearing and pin setup over simply letting the roller revolve around the pin.
