Jack_Shaft
I have to change the one-way bearing out on the RS engine in a 2006 VK Pro. Is there a generic puller that can be used to do this? Crowfoot? I am reading that the threaded receiver holes are M8?
Any suggestions or guidance from experience?
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
3 bolt puller, I use this one
https://www.ebay.com/itm/2972510404...PmpvNl3TKS8mCesdZbKfF6P3okiok8kQaAhxhEALw_wcB
Jack_Shaft
Ok, so any crowfoot style puller *should* work as long as you have the right thread (M8?) puller bolts 3x
- Apr 17, 2003
- Menno, SD
- Menno, SD
Yes, M8 x 1.25 x probably 75-80mm length
Jack_Shaft
Thank you for the specifics, I appreciate it.
- 6K
- 8K
- 16K
