YamaSpark
- Sep 21, 2017
- Greenfield, Minnesota
- 2016 SR VIPER S-TX 137 DX
How has the "new and improved" Viper engine been treating those of you who have it?
Any starter failures, oil or coolant leaks, oil burning, hard cold or hot starting, catastrophic engine failures (bent rods, toasted pistons), or any other issues?
Also, how many miles on your sled?
Thanks!
Thanks!
ccmviper
- Sep 11, 2016
- Newfoundland
- 2010 Nytro xtx
2016 Viper MTX 141
2018 M8000
No problems at all.
Pat Cat
- Nov 27, 2016
- Granby, QC Canada
- 2016 Arctic Cat ZR7000 LXR 137
2011 Arctic Cat Z1 1100 N/A
Previous:
2014 Arctic Cat ZR7000 Sno Pro 129
2013 Arctic Cat XF1100 N/A LXR 141
2009 Arctic Cat TZ1 LXR
2009 Arctic Cat T570
- Granby, QC Canada
1 season, 4200 km, no problems.
Carla 123
- Feb 27, 2017
- Lester beach
- 2015 viper xtx boosted
17 zr9000 precision stage 3
Haven't even ridden mine yet so I hope no problems lol
super1c
Moderator
- Apr 10, 2010
- Freeland - Otsego lake, MI
- 22 sidewinder LTX-LE
1200 on my 17 and 2000 on 16. No problems what so ever. Had a torrs issue on my 17 that was fixed with a simple adjustment. I wouldn't give buying a 16 or 17 any thought. Besides if I ever turbo'd I would do it right and have rods inspected and replaced if needed.
Cfpdscott
- Feb 23, 2016
- Illinois
- 2016 Yamaha viper Rtx-se
1200 miles on my 16 and no issues. Sled runs great and I believe they changed up some suspension settings in the skid as well giving it a better ride than years past but don't quote me on that. Some of the doom and gloom posts lead people to believe every new motor has bad rods which is not the case. I fully believe there are way less bad rods out there than people think.
JStat17
- Dec 30, 2013
300 miles on 16 ltx le. Loving it. No issues whatsoever
Yamajon1
- Nov 6, 2016
- Oshkosh Wisconsin
- 2016 SR Viper RTX DX
Former Yamaha sleds:
2004 Venture 600 2002 SX Viper 700
1997 Vmax 600 SX 1994 Vmax 600 1989 Exciter
1986 Vmax 540 1986 Phaser 1981 SRX 440
After being out of sledding for several seasons I bought a left,over 2016 RTX DX last season. Only got 500 miles on, poor season, but I had no major issues. Had 1 TORS issue fixed with throttle adjustment and first trip up north at minus 15 it did not want to start. Cranked but no fire. It eventually started after trying for several minutes and it never happened again. After reading several posts of starting issues when cold I suspect I may have had the frozen relay issue. I did not encounter temps that cold again last season so don't know if there is still an issue or not. After getting the sled ergos and suspension adjusted to my liking I have been very pleased with it. With some clutching it pulls like a freight train on bottom and mid range but is lacking on top end. No leaks of any kind. Other then the 1 time it has always started fine cold and hot. No kick back issues. My biggest complaint is the headlight. If you adjust it on low beam hi is to hi and useless. If you adjust it good on hi beam then low is to low and useless. Other then that so far so good. It is part Cat and some things do seem a little cheap, after riding Yamahas from 1984 to 2010 I might be a little biased. Looking forward to better conditions and more miles this season. I was not concerned about the rod issue since I have no plans to turbo. I'd get the Winder if I wanted a turbo.
InRBigness
- Apr 10, 2014
- winnipeg, manitoba
I have a 16 turbo. No issues at all what so ever. I have had the rods changed but old ones had 4000K on them and were fine. My motor looked like it was brand new. Hardly broken in the mechanic said. I now have close to 6000K and no issues with motor or anything else.
As for the head light I agree its a pain to get it right but Rocztoyz HID's helped out a ton.
Allan
2016 stx dx 146 12,000 km and not a problem. still on stock slides and got 8500km on first belt. sled is stock other than 8dn belt.
Happyhours
- Feb 26, 2015
- Oshkosh
- 2016 Viper XTX
2010 Apex
2016 with the turbo. 4000 miles on it. Just had the new rods put in and have not drove it yet. No issues with the engine at all.
- 33K
- 47K
