FX Nytro overheating
I don't think the speedometer cowl is the best place to open a vent either. Your going to have snow, steam, heat blasting you in the face. I did see a post were someone cut several long slits in the lower part of the side panels. It didn't look bad and might help with air flow but it also may cause more of an issue with wet feet. The BR Tech Vents for the side panels don't look bad either. I'm just not sure if it's the answer.
Has anyone consider running a secondary fan or maybe modifying the radiator fan into a dual fan setup?
What JDS1000 wrote is true the heat from the engine comes out those two little vents that our knees cover up, and at our feet primarily the left. There is not enough air moving through to keep cool so the snomobile overheats and so does our feet. So the tunnel heat exchanger is left to do the rest of the job. Its not enough when there isn't snow. If you look at the older snomobiles from the past the hood has many vents, the engine compartment is not as cramped and this gives air flow, what you need to cool. Adding another heat exchanger to the tunnel will probably help, but what about the rad under the air starved hood it needs more incoming and exiting air to cool.
There are vent kits out there, and I'm sure it would do two things cool the engine bay, and not be so hot on our feet. BRTechRacing.com is one, and maybe Sledsolutions.com
The speedometer cowl is over/in front of the exchanger so that would imo not help that much at all. A hood vent and bigger vents in the back/side of the sidepanels to escape the air could help?? Letting alot of air in doesnt help if it cant get out of there and that should the biggest problem.
Here are the mods I did to help remove underhood heat. I added some vents and drilled out some holes in a couple of body panels.
where'd you get that?
They're called XXXModrod vents. Found them searching another forum.
Summitseeker said:
Venting and Ice Scratchers should fix the problem! Try http://www.2coolairvents.com/ which has a great product. I just installed them on my T-Nytro. I use my own ice scratchers that I manufacture.
p.m. me on some scratchers...I need a set for my simmons..
Did anyone notice that the Yamaha race sleds are using collant filled tunnel protectors? I bet that would be the hot set up for getting rid of the ice build-up in the tunnel, plus would help with the running temp also.
I would agree, that would probably work.
anyone know what the actual coolant temp is when the overheat light comes on? is yamaha being conservative with the temp at which the light comes on??? just thinking out loud
Coolant light comes on at 212*F.
allen tried to call three times left msg
what about diluting the coolant..how much...and what about water wetter.. etc?
My 08 nytro overheated a few times(shut down twice); even with water wetter. My 09 xtx never ever overheated or had the light come on with 1/2 bottle of water wetter added.
