KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
Definitely will work on your phone mike
Most excellent! Thanks Dave
snowdust
- Oct 26, 2003
- Northern Illinois
- Sidewinder
If you are not fine tuning it sounds like there will be no need for an extra device right?
GAP Innovation
TY Advertiser
- Apr 28, 2017
- Repentigny
- ZR 9000 RR, Sidewinder
Hi Guys
Glad you like it! The following will answer a few questions:
Tune selection can be done in two ways:
-Using any supported Apple or Android mobile devices. It does not need to be fixed to the sled.
-Using an optional button installed on the handlebars
There are two display methods for knowing which tune is in function and get feedback when navigating the JukeBox:
-On the mobile App
-On the original instrument cluster
Of course, at least two tunes are required to have access to the JukeBox. The tune bundles will fill this requirement also.
Cheers
-On the mobile App
The GAP Flasher module connected to the sled is required to use the JukeBox.snowdust "If you are not fine-tuning it sounds like there will be no need for an extra device right?"
Cheers
saskattakman
this is slick..any way to add boost and afr to the stock gauge ?
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
Great work GAP! This is gonna rock.
Mike, I got the new iPhone X on order and got a mount setup for it(RAM MOUNT w/waterproof case setup). But will keep stock gauge in place too. Should work really nicely.
GAP, if one did not have any "screen" device on sled, and used the button for map switching, would the "live data" be able to be seen on stock gauges somehow? Im guessing no.
Dan
Dan
GAP Innovation
TY Advertiser
- Apr 28, 2017
- Repentigny
And also asked by ROCKERDAN...this is slick..any way to add boost and afr to the stock gauge ?
Eventually, we will add more items to the stock gauge. We have many ideas and are always listening to user requests and suggestions. Time-wise, we do not foresee this feature being released in the weeks to come. It’s a matter of months.
Keep in mind that the stock gauge capability will never allow achieving the same results as with a mobile App paired to a Bluetooth device like our Flasher. The good news is that the GAP Flasher already has everything needed to flash and interact with the stock gauge. Any future development will become available as an update delivered by the updater software already used by tuners for remap providing.
For keeping an eye on the boost, AFR and many more, the best method is to fix a mobile device on your sled. Connected to the GAP flasher, it's a very powerful combination. Many devices are compatible ( iOS or Android ), with multiple third party installation options available to fix and protect your device. We have developed and tested a complete solution using an iPad Mini 4. Granted, it's not the cheapest option but we are confident it's the best we can provide and know by experience that it's highly addictive. All of this is of course available right now.
Pstn head
So In order for this to work via Bluetooth to a mobile device fixed to the snow machine, the Gap flasher needs to be pluged into the snow machine and left there while riding ? I beilieve in the instructions it says not to leave Gap flasher pluged into vehicle, while riding. Will we need another version of the flasher tool ?
HURRICANE
- Oct 17, 2007
- Prescott Ont.
- www.hurricaneperformance.ca
Its true that you need to leave the flash communicator plugged into the sled while riding to access all the features. The instructions read not to leave the flasher plugged in while NOT riding for an extended time period such as a week
Pstn head
Got it , Thanks Dave.
NYTurbo
- Sep 26, 2017
- Ottawa
- Sidewinder
I don' think the antilag harness with the flasher installed draws power when key is not in the run position. I say this because when you plug in the flasher it doesnt light the led on the flasher with the key off.
The flasher plugged into the connector down by the chain case definitely is powered so draws power key on or off and lights the led on the flasher momentarily when you plug it in with key off.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
So the flasher connected(down near chaincase) will ALWAYS draw on battery? Even when sled key/ignition is off?
I often plug into battery tender if Im not riding for a few days straight, would this make leaving the flasher connected a non issue then?
Dan
Dan
NYTurbo
- Sep 26, 2017
- Ottawa
- Sidewinder
Yes it will Dan. I would think the tender would keep it charged.So the flasher connected(down near chaincase) will ALWAYS draw on battery? Even when sled key/ignition is off?
Dan
iceback
How weather proof is this ?
NYTurbo
- Sep 26, 2017
- Ottawa
- Sidewinder
I wouldn' want to take it swimming.How weather proof is this ?
KnappAttack
- Feb 19, 2004
- Welch MN
Dan
I ordered and received my iPhone holder and wireless charger from Amazon and got it this week Dan. Going to put it either up over the stock gauge or on the center of the bars where you run your Garmin at. Not sure which yet.
I have little $ invested as the holder was like $23 and the wireless charger and charge card for iPhone was $25. The wireless charger is supposed to keep the phone warm too!
- 10K
- 8K
