nards444
I dont like using it but sometimes starting fluid has to be used to get everything running the first time.
Could be a stator.
Could be a stator.
nealchick
might be
sounds like the fuel pump is bad or a relay to the pump
Glock30
- Apr 14, 2004
Motor runs so it is not a stator.
No relay on pump as it is carbed no EFI
SHodas
take the air cleaner off. Shoot starting fluid into all 3 carbs, quick shot in each, choke the machine, try starting it. I have been doing this for years on my 05 RX1, no issues. I also run my carbs and tank dry.
kinger
Did you use the blowing in the vent tube and pressurizing the fuel system trick? I have to do that every year on Dads Vector.
JROCK
- Oct 25, 2007
- Ottawa, Ontario
- 2006 Yamaha Apex GT
You could also try pressurizing the tanks by using small shots of compressed air. Undo the fuel vent line on the clutch side and crank, did this yesterday on the RX-1 started within a couple seconds.
Grimm
kinger said:Did you use the blowing in the vent tube and pressurizing the fuel system trick? I have to do that every year on Dads Vector.
That's what you need to do. The vent tube is attached to the frame by the left footwell. Detach it, blow into the hose as much as possible and then pinch it off. Then crank the engine over.
JROCK
- Oct 25, 2007
- Ottawa, Ontario
1 minute to late!! Great minds think alike and at the same time.
grizztracks
Tech Advisor
- Feb 24, 2005
- Scio, NY
Don't use starting fluid. get yourself a spray bottle at a dollar store, fill it with gas then mist fuel into the carb openings. Once it starts on the fuel it normally will pick up the gas in the tank. You may have to keep spraying gas into the carbs to keep it running until it picks up the gas and runs on its own. I'd recommend removing the drive belt while trying to get it started.
03RX1-ER-LE
Bleed BLUE
- Feb 22, 2008
- 2011 Apex XTX 12,497 miles
2009 Apex ER 8,169 miles
Tow Vehicle
2021 Wolverine X4
- Livonia Michigan
Do what u want on fuel source, I have used starting fluid for years without any concerns on any four stroke. However I would not remove drivebelt, if you rev it with no load/belt on the primary it may grenade. There are lots of warnings about not doing this for good reasons. ALWAYS leave the belt on while running the engine!grizztracks said:Don't use starting fluid. get yourself a spray bottle at a dollar store, fill it with gas then mist fuel into the carb openings. Once it starts on the fuel it normally will pick up the gas in the tank. You may have to keep spraying gas into the carbs to keep it running until it picks up the gas and runs on its own. I'd recommend removing the drive belt while trying to get it started.
Glock30
- Apr 14, 2004
I will try the vent hose trick tonight and repost either way.
Thanks All.
Thanks All.
Mighty
- Apr 17, 2003
- Grand Ledge Michigan USA!
- 22 Mach Z
23 Sidewinder SRX
This is what I had to do to my Warrior a few weeks back.grizztracks said:Don't use starting fluid. get yourself a spray bottle at a dollar store, fill it with gas then mist fuel into the carb openings. Once it starts on the fuel it normally will pick up the gas in the tank. You may have to keep spraying gas into the carbs to keep it running until it picks up the gas and runs on its own.
Glock30
- Apr 14, 2004
OK, I detached the clear vent hose from the frame, shot air in the hose with a computer cleaner air can and jammed my thumb over the open end. Cranked the machine for over a min. on and off....no go.
Am I doing this procedure correctly?
Grimm
You might wanna try spraying fuel in the carbs then.
