rtx15
It is hard to see in the 2nd picture below but there is lots of room for the bolt to move around. It makes setting the skis almost impossible.
I was thinking of attaching plates above and below (not sure how i am going to do this yet) and drilling the proper size holes in them then just using a longer bolt, any suggestions?
Mooseman
- Nov 3, 2009
- Greely, Ontario
- '07 Venture MP (gone)
'07 Phazer FX (gone)
'09 Phazer GT (gone)
'10 Nytro FX (son's)
- Greely, ON Canada
I had that happen to mine from the tie rod loosening. I just tightened the nut down and it loosened again. I re-tightened it again and it hasn't moved since. Maybe adding some washers, a longer bolt and double nuts will hold it all tight. Don't forget to drill a hole for a cotter pin like the original.
bsevigny
- Mar 25, 2006
- Minnesota
- 2016 Vector XTX 1.75 LE with Elka Shocks
2013 Vector LTX
2016 Polaris Assault with 159 track and 35" front
2009 Polaris RMK 700
Solution
Similar to cracks or worn holes in rails, take it to a good welding shop. They can weld in new material and then drill it out. Works great.
Bgs
Bgs
rtx15
- 47K
- 32K
- 148K
