earthling
- Dec 1, 2017
- 2021 SRX
2006 ATTAK
Oh, a 300 HP winder would never ever run with my old Pro-Stock 800, even a 350 HP winder wouldn't cut it. That not what I'm saying, you are not picking up what I'm putting down here....
I had a Simon turbo setup on a old Attak, we dynoed it on the engine dyno, it made 265 HP on a brand new zero mile engine with 11.8 lbs of boost on the engine dyno, took it right off the engine dyno, installed it right onto the track dyno and it made 150 Track HP with a bit less boost at 11.0 lbs. within an hour of running it on the engine dyno. So the Apex made 150 track HP not 132 track HP. The .5 would not work properly here.
Now, if you use a factor of .5 like there are using now that would be equal to a 300 HP Winder. We always used a .57 factor previously. Suddenly TD only has a track dyno at their facility and starts using a .5 factor. I'm just trying to figure out why as the .57 was always the most accurate in the past, not the .5 factor. Everyone and their brother used .56-.57 previously. Now I'm hearing .5 all the time. I just question why the change.
I fully understand what you are saying. You have the empirical data of having run your sled on an engine dyno (265 HP) and backed that data up with a track dyno showing 144HP, that is a driveline efficiency factor of .545 which means you lost ~45% of the power through the driveline components. If you look at a car scenario, you typically see 15-20% loss from engine HP to wheel HP, and another 4-7% on top of that if you use an automatic instead of a manual gearbox. That number, whatever it is, is not transferable from sled model to sled model because the drivetrains change quite a bit. .57 is a rule of thumb but in your case you can see that the actual loss was higher resulting in .545 or 45% loss in power through the drivetrain. When you improved your track HP to 150, the engine HP would have to go up proportionally to ~275HP unless you changed something fundamental about the driveline. My guess is that to get to 150, you were tuning more HP into engine, not playing with the driveline or a bit of both, but mostly engine because driveline changes are harder and result in lower gains. Your position on TD is that their track dyno number and conversion rate of .5 is artificially inflating their engine number. If they are, lets look at that. Their stated baseline was a 211HP stock winder. If the real world HP of a stocker is closer to 200, they are off by .053%. Their 300 HP corrected number would be closer to 271HP at the crank. Why the change? Marketing, miscalculating the driveline efficiency, marketing…. But Hurricane at least is in the same ballpark of stated numbers, and PEFI has a slightly different set of numbers but also a different approach to tuning. MCX has always said that any number over 250 HP with the stock turbo was questionable.
(Before I get flamed for talking smack about the tuners ——- I am not making any claims about what HP they are really producing)
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
On the Attak. I improved from 144 HP to 150 track HP by making only changes to the clutching, no HP improvements at the engine at all. If anything, we were down on engine HP because the boost was down .8 lbs. from the engine dyno, which would be about 8 HP down, I don't know why I'd have been down on boost from engine dyno to track dyno like that, its possible the track dyno was not loading then turbo as hard as the engine dyno, I don't know exactly, but we're splitting hairs here. The fact remains of all the tuners that have actually been on a track dyno and an accurate engine dyno is going to be using that .55-57 factor when the clutching is in the goldilocks zone. You'd need to be outta whack on the clutching a fair amount to be in the .5 factor range.
IMO the track dyno is for finding efficiency in the clutch department and the engine dyno is for developing engines and engine programs. Thats not to say that you cant improve on power like Allen is doing here testing the intake tube, but its not the best to determine engine power improvements, that best left for the engine dyno. A shop developing tunes and engines, needs to be doing so on an engine dyno, not a track dyno. I fully believe a 150 track HP sled is more than likely going to be around that 270 HP on a real engine dyno that its is to make 300 HP on the engine dyno. Yes, I fully believe engine HP numbers are inflated all the time in this industry. I've seen it happen for as long as I can remember. Check out Tommcats Facebook postings to get an idea on how far out to lunch they really are, he's posted some dyno sheets on there.
Simplespeed
- Jan 8, 2022
- 1191 Sauk Lane , Saginaw, Mi. 48638
- 2006 Apex , 2017 Sidewinder LTX -LE
Is 2:52 more costly to make ? I would think their is good reasons we don’t see 2:52 on the sidewinders ?Also worth noting the 2.52 is 3lbs heavier than 2.86. Additional rotating mass. No doubt, Allen's dyno doesn't lie!
Ahhh Allen beat me to it! ha
earthling
- Dec 1, 2017
- 2021 SRX
2006 ATTAK
If it weighs more, it likely cost more.Is 2:52 more costly to make ? I would think their is good reasons we don’t see 2:52 on the sidewinders ?
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
Who else purchased the turbo intake pipe????
I installed mine a while back but the sled isn't quite finished and there's no riding around here anyway.
Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
The intake pipe I got looks like it's 1/4 scale.
Must be working on the venturi principles.
I have one but its sitting in my parts inventory heaven right now. I probably won't install it until I need to do more maintenance on my XTX.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
This summer when I install the power steering I'll add the intake tube at that time.
It's on the shelf for.now.
REDLINE 1
- Sep 20, 2019
- ROUND LAKE IL
- 2018 TCAT
Mine is installed waiting for snow
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
I reference Tommcat's findings when figuring my calculations, because he's the only one who has tested a wide variety of flashes and is somewhat independent. Again, I wish I had the ability to engine dyno and then go to the track dyno, but unfortunately I don't, so I have to use what I have.
- Apr 17, 2003
- Menno, SD
- Menno, SD
Every 290+ flash that I sell gets one, included in my pricing and every sled I build in the shop gets one as well. I've only sold 2 otherwise (that I haven't installed myself).
Doc Harley
- Oct 17, 2016
- Here & there
Dynostar, Dyno jet & Mustang (automotive ) will show different numbers on the same day utilizing the same .5 smoothing & corrected factors.
Best to just look at the B4 & after effects.
Also, use the same Dyno/tuner throughout. Keeps things from getting confusing.
Doowithblue
- Mar 17, 2016
- Waterloo ON
- 07 Mach z x (sold)
18- RTX LE
I have a brand new one for sale if anybody's looking Ontario Canada save the tax I'll pay for the shipping within the province
