- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
REDLINE 1
- Sep 20, 2019
- ROUND LAKE IL
- 2018 TCAT
What did you use to glue it on ? PVC cement ?
Phatboyc
- Apr 2, 2007
- Ottawa, Ontario
- 2022 Sidewinder
Thank you for posting this. I had to look it up why you say this is not a pump gas tune. Hurricane 325hp tune runs at 24lbs boost. My lowly 240SS is far from that. lol
Thanks for posting this Allan.I had a chance to run this back to back yesterday. 24 lbs boost, so it's not a pump gas tune, this is on my chassis dyno, it went from 163 track hp to 165, or approximately 4 horsepower gain at the crankshaft. It's not terrible hard to change on a non-eps unit, simply remove the air box on the clutch guard, two steering post 10mm nuts, remove the BOV hose and then you can wiggle the tube out.
Did the Turbo Intake Mod add boost or did the boost remain the same?
- Apr 17, 2003
- Menno, SD
- Menno, SD
I actually didn't use any glue at all, I worked slowly to sand it and it was a "press fit" by hand. I put a little bit of silicone on it (very thin), but that was it.
Without doing motor work or running a mix of race gas or some sort of booster, you'll never run 24 lbs of boost on a stock turbo on pump gas safely.
It picked up about 150 rpm, I didn't watch the boost number, I was paying more attention to the engine rpm. I'll have to go back and compare logs.Thanks for posting this Allan.
REDLINE 1
- Sep 20, 2019
- ROUND LAKE IL
- 2018 TCAT
Ya silicon is a good call. Won’t come apart once cured. Tricky thing is you gotta get it clocked in the correct position when you glue it. From the pictures it looks like a pretty straight shotI actually didn't use any glue at all, I worked slowly to sand it and it was a "press fit" by hand. I put a little bit of silicone on it (very thin), but that was it.
- Apr 17, 2003
- Menno, SD
- Menno, SD
I marked it with a sharpie marker on the top before I made the cut, this way I could hold the original piece and the new piece and have a reference line for clocking it. I clocked it on the bench and just slid it in the sled, I didn't install, uninstall, glue, and reinstall. I just did it once.
Fleecer
- Jun 13, 2014
- 2019 SRX
Good info....thanks for sharing.I actually didn't use any glue at all, I worked slowly to sand it and it was a "press fit" by hand. I put a little bit of silicone on it (very thin), but that was it.
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
Guess I'm eating crow on this one!
I apologize to the Hurricane faithful and stand corrected.
Thanks for testing it Allen.
0degC
- Jun 5, 2009
- Sudbury, Ontario
- 2023 SRX, 2017 XF 9000
Just get a speed track and show us the 160mph this year… and all is goodGuess I'm eating crow on this one!
DMCTurbo
- Nov 12, 2005
Yes I did pick up a new speed track to shoot for 160Just get a speed track and show us the 160mph this year… and all is good![]()
- Apr 17, 2003
- Menno, SD
- Menno, SD
@Turboflash can verify, the Hurricane tube picked up a nice gain to the track on his Stage 4 tuned Precision setup yesterday on my chassis dyno.
STAIN
- Feb 29, 2004
- Vermont
- 2024 Arctic Cat Riot 9000
- Vermont
numbers????
Fleecer
- Jun 13, 2014
- 2019 SRX
I hate to be that guy, and hate to pry.......but have to ask:@Turboflash can verify, the Hurricane tube picked up a nice gain to the track on his Stage 4 tuned Precision setup yesterday on my chassis dyno.
As TF runs a monstrous tune, are the track hp gains larger than previously discussed??
Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
Come on T.F...give us the low-down. Lol.
I already have it but have other work to do B4 I put it on.
I wonder if TF quit the group? Hahaha
