tator
this is the intake i made for my hurricane 190 kit to move the intake away from the exhaust. i think i should get some frog skin to wrap the filter in now that it sucks outside air. also thinking of adding a vent in the hood where the intake is to allow more outside air in right where the filter is. my intake temps before this where around 90-110 with the intercooler, now with changing location only they are 50-70.
titanrcr
- Jan 3, 2011
- Old Forge, New York
- 2019 Sidewinder LTX LE
2015 Viper LTX SE
2011 Apex
Very nice tator and nice temp reduction!
STAIN
- Feb 29, 2004
- Vermont
- 2024 Arctic Cat Riot 9000
- Vermont
Do you have a part number on the rubber hose?
YAMMAROB
- Feb 11, 2013
- Dyer, IN
- 2014 XTX Viper Hurricane Turbo,
2015 MTX Viper
Sons: 2009 Phazer Suprecharged RTX Streched to 153
Will you make one for your Buddys?????
tator
the hose is a radiator hose with a pre bent 90 in it. 2 inch inside diameter. the one i used didn't have a spring inside it to stop it from collapsing so i put one in. the elbow i made from 2 inch outside diameter exhaust pipe cut at a 45 and then welded together. the part that took the time was the plate that bolts to the turbo, and welding it together. getting it in the right spot so it fits with the hoods closed. actually fits very nice and doesn't rub anywhere. I'm happy. going to houghton friday, can't wait.
Awesome!
Mitch Desorcy
MAX PRO
- May 6, 2014
- Winnipeg Manitoba
- 2014 Yamaha SR Viper LTX SE
I've wanted to do this, I am not a fan of the outside pipe look. But I really like where Push Turbo puts there intake. Very similar where Tator put his but a little further to the front.
yamalover93
- Nov 23, 2014
- Menomonie Wisconsin
- 2012 Yamaha nytro xtx
Just try to keep up with the nytros! Lol [emoji12]the hose is a radiator hose with a pre bent 90 in it. 2 inch inside diameter. the one i used didn't have a spring inside it to stop it from collapsing so i put one in. the elbow i made from 2 inch outside diameter exhaust pipe cut at a 45 and then welded together. the part that took the time was the plate that bolts to the turbo, and welding it together. getting it in the right spot so it fits with the hoods closed. actually fits very nice and doesn't rub anywhere. I'm happy. going to houghton friday, can't wait.
Sent from my SCH-I545 using Tapatalk
CustomApexMan
- Dec 28, 2010
- Ovid, NY
- 2014 XTX Viper MCX 270 HP
That's a pretty restrictive steel 90 should of pie cut some pieces to blend the corner better.
tator
i was thinking that. really wanted to find a bent or molded 90. first idea was a threaded pipe fitting but to get it to fit was a mess. i was thinking i would loose some boost but it still makes 6 at WOT, and cruising seems to be the same. I'm sure it restricts some but the benefit of 40 deg colder air seems to far out weigh the restriction. this was a "lets see if it works trial" during the summer i may look for something with a bend. just a tight space to do anything. was thinking a exhaust tip with the curve in it.
tator
you'll see friday. tail lights that is!
