- Apr 14, 2003
- Hessel, Michigan
Here is the start of the Nytro RTX project:
Just took the tool kit out, and there it is! It is a 2 lbs. bottle, and will have to have the siphon tube moved to the side. Wiring will be very easy, but the airbox will be a challenge on this one.
I will let you know more once I figure out the airbox nozzles.
kinger
- Jan 17, 2005
- Clear Lake, IA
- www.piergenius.com
Nice! I will own a nytro but probably in 3 years
- Apr 14, 2003
- Hessel, Michigan
Better yet, who would have thought a 2.5 lb. bottle would fit? It does, and still have an 1/8 inch clearance to the hood.
System is installed, and took less than half the time to do the Apex. Everything mounts on the top of the airbox lid, and there is plenty of room. Don't have to take out the bottom of the airbox to install the fuel plumbing.
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
Terry it looks great!!!!
- Apr 14, 2003
- Hessel, Michigan
Thanks Allen, just need snow now.....
cardguy
- Dec 11, 2004
- SW Ontario
- fx nytro
Have you tested the Nytro on the juice yet?
just wanted to know , cause i'm thinking of juiceing mine.
- Apr 14, 2003
- Hessel, Michigan
A couple of spurts, but no full runs as I need to get RPM's down to 8,400 at least.
Just got an email mentioning some tricks, so I will play with it this weekend. Working good, just need to fine tune.
sledmontana
- Dec 28, 2007
- Southwest MT
- www.powderpilots.com
HI NOS PRO, how did it go? I am looking at a 60 hp for my nytro, is that what you have there? Just want to add a little all around fun and shot for powdery hill climbs, etc.
- Apr 14, 2003
- Hessel, Michigan
sledmontana said:HI NOS PRO, how did it go? I am looking at a 60 hp for my nytro, is that what you have there? Just want to add a little all around fun and shot for powdery hill climbs, etc.
Advertised 45 horse shot, and working well. About 30 lbs. thru the sled now. The 60 would be great for mountain areas, but just need to run mid-grade or Premium fuel.
sledmontana
- Dec 28, 2007
- Southwest MT
Which Kit was that? Any additional little parts or special tricks to get it dialed in?
- Apr 14, 2003
- Hessel, Michigan
The kit installed on Barry's friends sled pictured above, works great! He has put 70 lbs. of nitrous thru the sled to date, with 0 problems. It is a Holtzman system 45 horse. Just takes a good day of tuning to fine tune, but will give you great results right out of the box. Been real busy, so I have not been posting a whole lot on here lately. Just happened to stumble on this one....
Race_blue60
is that line in front,behind or next to the breather tube when the airbox cover is on?
