KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
My problem with these frogskin type screens is they do NOT flow very well.
So I just grabbed a cat nose vent for certain days if/when snow is really deep and wet and piles up alot on stocker. Switch over quite fast and completely reversible back to stocker.
I agree, plus if the Cat grill still plugs up, its real easy to just hot glue some frogskin material on the Cat grill outside edges and get what I think will be less blockage and less snow buildup like dieselxtx did on his which has proven itself. It also looks to flow better with more square inches of frogskin fabric on the entire molded Cat grill as well.
Here is a pic of his setup.
Beerman
- Nov 22, 2004
- Plymouth, MN
- www.loyalshepherd.com
- Sidewinder LTX-SE
- YOUTUBE
- arttyszka
Looks AWESOME!I bought Travis guard, its a very well built unit, and it fits perfectly.
I added my own twist, I didn't like the naked look without the shroud so i hacked up the factory one to allow travis great creation to complement the stock setup.
Let me know what ya think!!
View attachment 132752 View attachment 132753 View attachment 132754 View attachment 132755 View attachment 132756 View attachment 132757 View attachment 132758 View attachment 132759 View attachment 132760 View attachment 132761 View attachment 132762 View attachment 132763 View attachment 132764
XP123
- Dec 25, 2016
- Chautauqua NY
- Sidewinder XTX LE 137
I think I'm going to do the same thing I did last season with the intercooler guard.
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
Looks good! Glad you shared as there are a few others that wanted to try and put the stock nose cone on.
In addition to doing away with the shelf, part of my logic for doing away with the stock nose cone is to expose the entire intercooler to snow dust. If the ends are exposed to snow and direct air flow, the intercooler will be more effective at dissipating heat. Melting snow is even more efficient at dissipating heat than air.
My guard also opens up the door for the addition of an intercooler fan. The guard provides clearance for the cooler to be rolled front and create some more room to work with on the backside for a fan. I will be testing fans this winter.
In addition I have a coolant radiator and fan set up that will not fit under the hood unless I roll intercooler forward a bit. If I decide to market these kits I needed a solution to get the intercooler forward a bit.
As you can see there's a lot of motive behind why I even created the guard. I have no issue with the cat grill and frogzskin. Its a very cost effective solution to plugged up grill. If all I was concerned about was snow build up, then I would have scratched this product long ago as there's no need to compete with the cat grill set up.
- Apr 14, 2003
- Hessel, Michigan
Fan for the innercooler and a radiator with fan (Have an apex radiator that I picked up with fan I was going to try)
Now your talkin!!!
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
Like it...how did you secure the frog skin? pics?
Fans behind the intercooler defintely work, I have a custom intercooler on my Sidewinder with dual electric draw through fans behind it. Works good on the warmer spring days and days with groups that don't move as fast as id like to be going. Datalogging shows a definite improvement. Nothing huge but they work!
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
2018 snoscoot
Good to hear. Do the fans run all the time? Can you post some pics of your set up?
They are wired to a rocker switch I have on the dash, I'll post a picture of the setup. Builder is no longer a site vendor so the picture is just of my setup. Not pushing their product or trying to start any unneeded drama over it.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
Very cool.....love that labeled rocker switch!
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
Love that...awesome setup....whos intercooler?
nvm ...just figured it out ..JF
Correct SJ, I sourced the rocker switch from Amazon I believe, They come in multiple back lit colors so any sled could be matched. I put it in the factory heated seat hole. Moved the heat seat switch down and center on the console and then to go right of that equal to the fans switch in position I have another back lit rocker switch that turns on and off my powermadd led handgaurds. Trying to go for a factory like appearance on the build
I also just got Travis's barn of parts intercooler guard on Saturday so I'll be installing that this weekend. Great product as always from Travis!
- Apr 14, 2003
- Hessel, Michigan
Got my guard yesterday...thanks Travis!
- Apr 14, 2003
- Hessel, Michigan
I copied you silverram
Thanks again @hibshman25
- 15K
