Richard Hodgins
- Mar 5, 2019
- Ottawa ontario
- Yamaha powered CAT
Has anybody used this yet, and who makes it?
turbodynamics.mybigcommerce.com
It says its supposed to help with harmonics and quite a bit cheaper than other vibration elimination kits (Hurricane one).
Just wondering if it actually works and what the advantages are. To install, it's as simple as pulling the stub shaft and popping it in?
Arctic Cat/Yam Knock out Kit
Turbo Dynamics Webstore Arctic Cat and Yamaha turbo performance Sidewinder SRX Thundercat ZR9000 XF1100 F1100 Z1 M1100
Turboflash
- Mar 18, 2019
- Southern MN
I guess I'd need more info. Don't see how something that small and light would make a difference.
STAIN
- Feb 29, 2004
- Vermont
- 2024 Arctic Cat Riot 9000
- Vermont
Interesting.
Are you trying to get more life out of your primary clutch wear items?
Richard Hodgins
- Mar 5, 2019
- Ottawa ontario
I'd imagine less harmonics will help clutch life, both on a cat or yam primary. May also get rid of the rattle on the yam clutch?Interesting.
This seems like a new product, so just wondering if anybody has used it and if indeed there are benefits.
Rtbo
- Feb 18, 2016
- N Syracuse
- 23 SRX
- N Syracuse
I think td makes them. They say it quiets down the clutch rattle. I just ordered one when I ordered my tune bundle but I have to send out my Ecu and they will send everything back with it. I’ll post back when I get it.
NYTurbo
- Sep 26, 2017
- Ottawa
- Sidewinder
It’s made by TAPP
earthling
- Dec 1, 2017
- 2021 SRX
2006 ATTAK
It has a small o-ring inside that adapter. According to TD/TAPP its pull the clutch, clean the shaft, lube her up, put back together and run. The TD guy was adamant that it reduced noise so I put it on the birthday list for my daughter to get me. I can get better pictures if you are interested Richard, its sitting here next to the computer.
Turboflash
- Mar 18, 2019
- Southern MN
So, exactly how/why does it work? I know mass affects balance/resonance/harmonics. But it's so light relative to weight of crankshaft/PTO snub/flywheel; why/how does it matter? Or, is someone just trying to sell stuff? Is this thing like "blinker fluid?"It’s made by TAPP
NYTurbo
- Sep 26, 2017
- Ottawa
- Sidewinder
U need to pull the stub shaft. hAS nothing to do with weight. ILL be installing one next week for a customer
Turboflash
- Mar 18, 2019
- Southern MN
I understand that but again, what makes it work (supposedly)? Does it limit or control clearances in fit of PTO snub to crank, if it's not mass/inertia?U need to pull the stub shaft. hAS nothing to do with weight. ILL be installing one next week for a customer
NYTurbo
- Sep 26, 2017
- Ottawa
- Sidewinder
FRom what I can’t tell u fill the stub shaft splines with grease and the grease absorbs the vibration, o ring holds the grease in. Does it work ? Many claim it does
earthling
- Dec 1, 2017
- 2021 SRX
2006 ATTAK
How frustrating would it be for this to really work and for Yamaha to not have solved this issue a long time ago.
Rtbo
- Feb 18, 2016
- N Syracuse
- 23 SRX
- N Syracuse
The guy I talked to at td said you pack the splines full of grease and put the collar on. It will not hold the stub shaft out of you blow a belt
Heck for that price I'm willing to try it out!
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
Ya no kidding! I'm suprised it's not $500!Heck for that price I'm willing to try it out!
- 43K
- 52K
