SumpBuster
- Jul 18, 2003
- Carlisle, NY .
- 18 sidewinder; 06 Apex RTX
Another great idea. Guess Ill have to do it twice to see!Yes, I own a mighty set-up,Whatever...the $3.00 syringe works better. Suck the master dry. Fill the syringe & attached tube with brake fluid, attach to bleeder and send it until master is full. Once you see fluid coming up, give the brake lever a couple of light taps during the fill process.
Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
Best way to break these bolts loose on the caliper?
Also, I tried putting a little heat to that banjo and it's not moving either
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
Don't take it apart if you don't have to, bleeding can be a real bugger. Only reason to take apart would be to free up the pistons.
SumpBuster
- Jul 18, 2003
- Carlisle, NY .
Can you get Travis' new bearing and collar on without taking the caliper apart?Don't take it apart if you don't have to, bleeding can be a real bugger. Only reason to take apart would be to free up the pistons.
Im not there yet,but curious.
STAIN
- Feb 29, 2004
- Vermont
- 2022 SIDEWINDER LTX GT
- Vermont
no. not enough roomCan you get Travis' new bearing and collar on without taking the caliper apart
vacuum bleeder makes short work of it.
or back fill as shown in earlier posts
stgdz
- Mar 27, 2021
- Buffalo MN
So in regards to that lite weight caliper
This was mine last year
I've put about 400 miles on the new pads and haven't seen many issues. One thing I'm noticing is that my left foot is getting warm as is the brake guard with those sintered pads.
bleeding brakes?
I have a compressor version of that. It didn't work Maybe something different in system. This has worked perfect and simple many times in my dads and my winder every year as part on summer PM
ty4stroke.com
SumpBuster
- Jul 18, 2003
- Carlisle, NY .
Seems crude but years ago when we had socket head screws stuck in die sets, a hammer and a prick punch with someone loosening did the trick. Or try a light duty impact, tight then loose. The vibration can break whatever bond is holding them. Ive found putting too much torque on an allen wrench rounds the hex on the non American made fasteners. Years ago, not so much, the bolts and stuff were much better made in the US.Best way to break these bolts loose on the caliper?
Doc Harley
- Oct 17, 2016
- Here & there
I wasn't interested in disassembling it but sometimes you have no choice.Probably would have been better to leave it secured to the sled.Don't take it apart if you don't have to, bleeding can be a real bugger. Only reason to take apart would be to free up the pistons.
yeah, no. Has to come apart. The new bearing collar is probably 3/4" past the caliper housing. I don't even have it yet.Can you get Travis' new bearing and collar on without taking the caliper apart?
Doc Harley
- Oct 17, 2016
- Here & there
If it takes you more than 30sec to line up the bolts in the back of the caliper housing. Try this. Zero stress
rev them up
- Apr 3, 2006
- Prince Edward Island, Canada
- 2011 Nytro XTX, Hurricane Exhaust, K&N, Pcv, Autotune, Pod300, Star Suspension,
2018 Sidewinder, TD Max Spool 17, CAI, TD 3 Inch Stock Muffler Mod, 3Bar, BOV
If you have to take it apart the easiest way i found to bleed was to put a container by the bleeder, open it up 2 turns and let it flow all the while pouring new dot 4 in...once you see new fluid close it up and fill the reservoir up. Only way i could get mine...took 30sec...i tried other methods, this worked the best. Wouldn't believe how dirty the old fluid was.
Doc Harley
- Oct 17, 2016
- Here & there
The fluid in the caliper was definitely dirty. I'm going to try the syringe trick and push the fluid up through the brake bleeder to the master. If that doesn't work I'll resort to your plan.If you have to take it apart the easiest way i found to bleed was to put a container by the bleeder, open it up 2 turns and let it flow all the while pouring new dot 4 in...once you see new fluid close it up and fill the reservoir up. Only way i could get mine...took 30sec...i tried other methods, this worked the best. Wouldn't believe how dirty the old fluid was.
And I will come here and post up what my findings are.
Having the caliper apart it's easy to understand where air bubbles can hide.
STAIN
- Feb 29, 2004
- Vermont
- Vermont
I bet that fluid gets HOT pulling these tuned winders down from high-speed runs.Wouldn't believe how dirty the old fluid was
Brake fluid is the most overlooked maintenance item there is.
stgdz
- Mar 27, 2021
- Buffalo MN
That's one reason to do the reverse bleed. You can tell when you get all the bad stuff out.I bet that fluid gets HOT pulling these tuned winders down from high-speed runs.
Doc Harley
- Oct 17, 2016
- Here & there
Trust & believe in the giant syringe. Really you just need to adjust flow by turning bleeder counterclockwise while hose is feeding the bleeder brake fluid.
Break pull feels like factory. But I'm sure that will change a touch while out riding.
Phatboyc
- Apr 2, 2007
- Ottawa, Ontario
- 2022 Sidewinder
Can the bearing be re-greased without removing it from the caliper? On the Delta chasis, removing the seal in place was easy with pics or tiny flat screwdriver.Just a guess but maybe after heating the caliper they recommend bleeding it to remove any air if any..
I take out mine every year to clean inspect and regrease without any heat, once the circlip is removed that holds the bearing in the caliper i use a socket that fits inside the caliper and catches the bearing, on the side of the clip I made up a rig that only catches the caliper shaped like a U with a hole in the centre, put the bolt through the socket and through the U shape bracket and tighten a nut on and the bearing comes right out.
Sorry I don’t have the puller with me to post a pic.
- 35K
