Looking for help on how to hold primary clutch for torquing?
JayM
Pickering, ON
Canada
2017 Sidewinder R-TX SE
Hi all,
I'm struggling to figure out a good way to hold the primary so I can get it torqued to the 108ft lbs. Using a small pry bar between the primary posts is pretty much impossible to hold it from spinning backwards due to leverage and can't fit a longer pry bar there. Also I fear I'm going to break the clutch.
I tried searching but only found torque specs not really any pics or video on how to hold it.
Thanks!
Buy clutch holder, or put your bar thru clutch horizontal to under secondary to hold while torquing, do this in a pinch if you have to just wrap rag on bar not to scratch
Wooden dowel in the clutch...
Slide a wooden dowel between the towers. Tighten clutch.
Other end on the secondary? No issues wih the dowel breaking at 108ft lbs? I assume it has to be a big enough dowel.
Hammer handle works.
Axe handle through clutch and under a-arm. In field I have used breaker bar same way and never hurt a thing.
img_9748-jpg.131719
