Goober01
- Jan 5, 2017
- Galesville wi
- Viper
- Galesville wi
Bent up a oil deflector and installed it in the top of the chain case to force lube to hit the upper sprocket and bushing area better
Goober01
- Jan 5, 2017
- Galesville wi
- Viper
- Galesville wi
That might do the trick! Very good idea.
grizztracks
TY Advertiser
- Feb 24, 2005
- Scio, NY
It would be interesting to see how the lube moves through the case so that we could see if there was actually a troubled area. That deflector might starve the return side of the chain which is were the tensioner is.
Goober01
- Jan 5, 2017
- Galesville wi
- Viper
- Galesville wi
I think the oil is flying right on by this area maybe this will let it drop in where it is neededThat might do the trick! Very good idea.
I will let you know in the spring how it worksIt would be interesting to see how the lube moves through the case so that we could see if there was actually a troubled area. That deflector might starve the return side of the chain which is were the tensioner is.
grizztracks
TY Advertiser
- Feb 24, 2005
- Scio, NY
Hard to tell what it's doing in there unless you can visually see it in motion. It may take several seasons before any assumptions can be made on what effect it has on wear. Why do you believe it's needed?
Goober01
- Jan 5, 2017
- Galesville wi
- Viper
- Galesville wi
Upper bushing in drive grear not holding up
STAIN
- Feb 29, 2004
- Vermont
- 2024 Arctic Cat Riot 9000
- Vermont
That top gear bushing is known to wear @3000 miles. The chain and case seems longer most others which may explain the trouble getting lube to the top of the case. This looks like a good idea to me, I cant see it doing any harm.
grizztracks
TY Advertiser
- Feb 24, 2005
- Scio, NY
are we talking about the wobble bearing?
STAIN
- Feb 29, 2004
- Vermont
- Vermont
No, the upper gear bushing.
Goober01
- Jan 5, 2017
- Galesville wi
- Viper
- Galesville wi
I see know harm in tryingThat top gear bushing is known to wear @3000 miles. The chain and case seems longer most others which may explain the trouble getting lube to the top of the case. This looks like a good idea to me, I cant see it doing any harm.
STAIN
- Feb 29, 2004
- Vermont
- Vermont
I wonder if that bushing had a slot in it if it would get oil better.
savageman69
- Apr 21, 2014
- 2014 arctic cat zr 7000 limited
well my gear bushing has 6000 miles on it and is not wore out
Goober01
- Jan 5, 2017
- Galesville wi
- Viper
- Galesville wi
What kind of oil do you have in it?well my gear bushing has 6000 miles on it and is not wore out
STAIN
- Feb 29, 2004
- Vermont
- Vermont
Have you looked at it? When that bushing wears it kicks out of forward gear, allowing only reverse. Seen it 3 times now.well my gear bushing has 6000 miles on it and is not wore out
- 12K
