nherbst454
- Feb 25, 2014
- Woodbury, MN
- 2014 SR Viper XTX-SE
Link to the Facebook page?
Studroes144
- Oct 30, 2013
So this thread kinda stopped cold turkey..any pictures and info ever get taken or are they hush hush?
Are you kidding? Basically all the info needed is out there. If someone cant put 2+2 together to figure out what to do then they shouldn't be touching a Lathe or mill and should use a Vendor to do this.
titanrcr
- Jan 3, 2011
- Old Forge, New York
- 2019 Sidewinder LTX LE
2015 Viper LTX SE
2011 Apex
From the little bit I've looked at and studied the clutches, would it work to simply machine the helix around the shaft area where it contacts the actual clutch body itself? This would be a SIMPLE way to allow for more travel in the secondary
Well yes, thats correct for the secondary. In the past I have used a lathe or just an end mill in a drill press to accomplish this on a stock helix.Very simple. On your primary you could install an aftermarket inner sheave (speed sheave) or just machine some material off the inner diameter of the inner face to allow it to close further. Just don't make the flat too big, you need the belt to engage on the angled face. I've done this many times. So if you have access to a lathe and feel that you can safely operate it go for it.
Studroes144
- Oct 30, 2013
No access to a lathe and def not interested in "making chips" on my own clutches lol just curious how Terry made out on this, it was a hot topic for a few days then just died
titanrcr
- Jan 3, 2011
2015 Viper LTX SE
2011 Apex
I agree, the machining is cheap enough to have done anyway. BTW, some of the aftermarket helixes are ready for overdrive out of the box.
nherbst454
- Feb 25, 2014
- Woodbury, MN
titanrcr
- Jan 3, 2011
2015 Viper LTX SE
2011 Apex
View attachment 100812 Machining the spring pocket a bit deeper to eliminate coil bind.
Nothing like a pic!
Studroes144
- Oct 30, 2013
By doing what's shown there will eliminate the coil binding, but does that allow for full shift of the secondary? From what I've seen many guys are still saying they machine sheaves yet too to reach full shift
titanrcr
- Jan 3, 2011
2015 Viper LTX SE
2011 Apex
No, a stock helix can still limit full shift if the primary has been machined for O/D.By doing what's shown there will eliminate the coil binding, but does that allow for full shift of the secondary? From what I've seen many guys are still saying they machine sheaves yet too to reach full shift
Lost me at soft porn...tff
2014 viper, mpi
2009 Phazer 144"
2014 viper, mpi
2009 Phazer 144"
Studroes144
- Oct 30, 2013
Ya I lost total interest once Mexican porn became the discussion lol, was just thinkin of it tonight and figured I'd look back and see if anything ever came of it
It was dropped because NOS Pro didn't want to step on any vendors toes by posting dimensions and pics. That's why I made the kidding comment. Sometimes old posts are better left old. I understand why you are interested now that you have a turbo Studroes. Can't you check to see your shift out with marker and removing springs after some runs to see if you are using full travel? I assume your secondary spring doesn't bind like stock anyway.
Its just as easy to mail the clutches in unless you have the Mill and Lathe at your finger tips.... and if you are any kind of machinist you should be able to look at your clutches along with a few other posts that are on the site and be able to figure this out.
Kerrdog569
- Sep 11, 2014
- East jordan,michigan
- 2017 Yamaha sidewinder xtx se
Maching by the pro's is way cheaper than buying new ones to send out for machining if ya know what I mean,I left it to the pro'sIts just as easy to mail the clutches in unless you have the Mill and Lathe at your finger tips.... and if you are any kind of machinist you should be able to look at your clutches along with a few other posts that are on the site and be able to figure this out.
