Vilas
- Sep 6, 2014
- Urbana, Illinois
- 2014 Viper xtx, Thunder products clutch kit
Beautiful work!
birkebeiner
- Jul 27, 2009
- Norway
- Norway
- 2015 Yamaha SR Viper X-TX
Got my Ulmer Racing clutch kit and Schmidt Bros Racing Quiet Shims kit today. Will install them over the weekend
NEEEEED SNOW!!!
Sticker is upside down
Birkebeiner
NEEEEED SNOW!!!
Birkebeiner
birkebeiner
- Jul 27, 2009
- Norway
- Norway
Well, I couldn't wait so I went to the garage and installed the clutch kit, shim kit, 8DN belt, OSP Belt Adjuster and RAM GPS mount
These are Ulmer Racing flyweights
Stock vs Ulmer flyweights
Installed
New OYO spring, stock to the right. It's slightly longer
New red spring, and it's slightly longer than the stock one. The diameter is same on both
New helix, to the right. Ulmer's helix has slightly more space for the spring compared to the stock helix
Added the Schmidt Bros roller shims. They do take out quite a bit of slop from the roller bolt & nut.
Took off the secondary and removed the three bolt from the inside, the shaves closes completely, and installed the new helix and spring and the OSP Belt Adjuster together with the 8DN belt
This is how my belt sits on the secondary now. I haven't adjusted any further and haven't let her run to let the belt set itself
I have this on the left side panel in front of the clutches, is this vent there stock?
I took off my GPS mount from my Nytro and put it on the Viper. I had to move the brake handle a bit to make it fit (not a lot of space on these handle bars!)
Now waiting for my Curves to arrive
Birkebeiner
Installed
Birkebeiner
Dirtbikekid1998
- Mar 3, 2013
- Maine
- 2014 Yamaha Viper LTX SE Hurricane 190hp Turbo.
Yes that vent on the clutch side is stock
And awesome sled by the way!
birkebeiner
- Jul 27, 2009
- Norway
- Norway
Thanks kid
Birkebeiner
Birkebeiner
swampcat
- Mar 17, 2014
- N. E. Wi.
- 2020 S W LTX-GT
BRAVO to you sir, that what I call a informative post. Outstanding pictures, well written. Like all the subliminal stickers.
birkebeiner
- Jul 27, 2009
- Norway
- Norway
Thanks cat
Birkebeiner
Birkebeiner
birkebeiner
- Jul 27, 2009
- Norway
- Norway
Here is a short video of the Schmidt Bros quiet shims. They go on the roller bolt & nut. Quite a bit difference in the bolt movement / slack.
Birkebeiner
Birkebeiner
putz21
- Apr 15, 2013
- Tomahawk, WI
- '25 Sidewinder XTX LE w/EPS
'23 Sidewinder LTX LE w/EPS
Video doesn't seem to work.Here is a short video of the Schmidt Bros quiet shims. They go on the roller bolt & nut. Quite a bit difference in the bolt movement / slack.
Birkebeiner
birkebeiner
- Jul 27, 2009
- Norway
- Norway
That's strange... I can't play it either right now. I watched it an hour ago... Will check it out!
Birkebeiner
Birkebeiner
birkebeiner
- Jul 27, 2009
- Norway
- Norway
Does work for me now.
Birkebeiner
Birkebeiner
Really a great write up! Thanks for taking the time.
Video says its private. Maybe that can be changed? Interested in those shims.
birkebeiner
- Jul 27, 2009
- Norway
- Norway
You're right, wrong setting from my side. I've changed it now
Birkebeiner
birkebeiner
- Jul 27, 2009
- Norway
- Norway
Here is a short video of my clutches after I put in the Ulmer kit
- 7K
