I emailed Yamaha Canada, and they replied right away and said there was no reflash. One hand doesn't know what the other is doing.
Have Patience. Its coming. Last time they rolled it out in Europe first if I remember right. Its a good thing. Remember the first 16 flash the speedo was off on most? They need to get this right the first and final time!
toddszr600
Ive got a buddy that runs the service dept at the local Cat dealer, I,ll have to check with him.
I havent had any real issues with the last one, occasional 2 start in morning, usually good for the rest of the day. Certainly no stalling or earth shattering kaboom backfires thank god!
Kirt70camaro
Do they charge for the upgrade flash? I have a 2014 7000
No chargeDo they charge for the upgrade flash? I have a 2014 7000
Kirt70camaro
Anyone ever feel like they have lost any power from the new tune?
Motorboat
I don't feel I lost any power from the last flash. That is when my starting issues started however. Anytime the temp gets to -5 or -10F it won't start. And the back fire almost blew me out of the trailer a couple of weeks ago. I look forward to this flash for sure.
I agree. Maybe even a little gain in power depending on if your modded or not. Stock should have seen better mpg and a little more snap at cruising range since they did lean it out a bit there from what I saw.I don't feel I lost any power from the last flash. That is when my starting issues started however. Anytime the temp gets to -5 or -10F it won't start. And the back fire almost blew me out of the trailer a couple of weeks ago. I look forward to this flash for sure.
cobrajet ltx dx
Hopefully someone can chime in on there experience with a 19 viper this season in severe cold startups.
Would give a good indication if Yamaha really has a handle on this ongoing issue for all pre 19 vipers.
Since IMHO... the 1049 is not in there future plans, hopefully Yamaha put some effort into correcting this for there current and future customers.
Yamasledder
- Mar 7, 2010
- Brandon, Manitoba, Canada
- 2020 Viper LTX SE
Yes. Mine seemed a little more crisp on the throttle after the 2016 flash. My 2014 is stock except for a MBRP trail can. I'd be interested to see what the ignition timing curve looks like as mine runs really well once it gets a little bit of heat in the engine. On cold startup it really behaves as though the timing is severely retarded. Even if it doesn't happen to backfire through the exhaust, it really labors as its idling like an engine with late timing.I agree. Maybe even a little gain in power depending on if your modded or not. Stock should have seen better mpg and a little more snap at cruising range since they did lean it out a bit there from what I saw.
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
Just released this morning!
Yamasledder
- Mar 7, 2010
- 2020 Viper LTX SE
Well; that is good news. I hope it improves things. I just phoned my dealer and they have it there but I can't get in until next Thursday to get it done. I'll update with results when I have a chance to ride it after that.Just released this morning!View attachment 143942
It would be nice if others report their results as well after the new flash.
aproudcanadian
- Dec 18, 2016
- new brunswick
- 2020 ski doo 900t x
Had my womans xf7000 done yesterday sled starts up great cranks over a tad longer, you can give it fuel when its cold and it wont stall like it used to, and idle is alot smoother no more hunting. Put 130km on last night and no issues at all!!
