Phatboyc
- Apr 2, 2007
- Ottawa, Ontario
- 2022 Sidewinder
Anti seize or else...this guy was trying the lock up method. lol
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
That looks like a sled from a salvage yard.
It just means they didn't want to put too much effort into this as they're busy with the totally revamped Winder 2.0 for 2023So it looks like they changed the bushing material on the gear, added some surface material to the Upper Driveshaft i:e Jackshaft then hardened the Driveshaft.
Sorry, i'm not convinced here. Hope i'm wrong.
If the bearing is still loose and "harder", it's now gonna eat the bearing.
The skinny top gear with all that weight/ force on it is gonna eat through this "coating" like the shaft used to eat through the gear coating.
The DMC has a much wider surface to spread the "weight". That's the fix.
The bearing needs to be snug then locked somehow.
I hope this helps cuz in 2 years, i'll be buying a new sled.
Phatboyc
- Apr 2, 2007
- Ottawa, Ontario
- 2022 Sidewinder
Ha ha my turn to have some fun.That looks like a sled from a salvage yard.
- Feb 13, 2017
- Amston,CT
- Renegade 900 ACE,XF 9000 Crosstour,2024 Skidoo Renegade XRS 900R
After looking at all the previously posted pics/comments,my one and done anti- rotation pin,slotted inner race,with a better bearing ,still looks like a long term fix.My Yamaha dealer did not want to revisit this issue every year.Good luck. He accepts used shafts for refurbishment,pin installation, with a bearing slotted inner race.Franks motorcycle sales/service .1-802-878-3930
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Very interested in this! I will be looking into this after this season as I have 2 that I want done.. What's he charging for this?After looking at all the previously posted pics/comments,my one and done anti- rotation pin,slotted inner race,with a better bearing ,still looks like a long term fix.My Yamaha dealer did not want to revisit this issue every year.Good luck. He accepts used shafts for refurbishment,pin installation, with a bearing slotted inner race.Franks motorcycle sales/service .1-802-878-3930
Turboflash
- Mar 18, 2019
- Southern MN
None are or have ever been press fit from factory unless there was unicorn somewhere.What is so bad about the Peer, a SKF company, bearing? 6500 miles and my bearing was fine. Just spun.
New shaft in 2020, new bearing, BOP wedge began to lock at 20ftlbs, clicked it to 40ftlbs, and done.
Did this on both sleds.
If the new 2020 shaft was machined any tighter it would have been a press fit.
You're saying the 2021 shafts are machined loose?
It's not the bearings fault if the mfg can't machine to spec.
Too hard to mass assemble on assy line and too hard to disassemble (service event) if pressed which is why it isn't.
IMO, BOP wedge should still work and still be used unless you do one of the other fixes.
Turboflash
- Mar 18, 2019
- Southern MN
Yup. This one too ....
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Some are tighter then others no doubt about it.. My second shaft that was replaced under warranty was very good clearance if there is such a thing. This 22 is a different story, but with that being said with a wedge from ZERO MILES i have a chance at preventing wear/slippage.. But what concerns me the most is the guy that does nothing to address it from the factory..
FrozenTows4
- Nov 6, 2014
- Brainerd Minnesota
- 2014 XF7000 Sold
2017 ZR6000RS
2018 ZR6000 El Tigre
- YOUTUBE
- FrozenTows1
Agreed. How do we get the word out that Every ProCross chassis sled should be brought in for warranty service?Some are tighter then others no doubt about it.. My second shaft that was replaced under warranty was very good clearance if there is such a thing. This 22 is a different story, but with that being said with a wedge from ZERO MILES i have a chance at preventing wear/slippage.. But what concerns me the most is the guy that does nothing to address it from the factory..
Then maybe Yamaha, Arctic Cat, and Textron will wake up and address the issue.
The chaincase side spins too. Just not as bad. Why? Why does only the caliper side spin so bad?
- Feb 13, 2017
- Amston,CT
To spray weld and machine a used driveshaft (shaft sent to him) for anti rotation pin installation,and to provide a modified upgraded bearing with the inner race slotted,was $180 ,shipping extra .service advisor is Kamran PelkeyVery interested in this! I will be looking into this after this season as I have 2 that I want done.. What's he charging for this?
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Thanks for info! That's reasonable!To spray weld and machine a used driveshaft (shaft sent to him) for anti rotation pin installation,and to provide a modified upgraded bearing with the inner race slotted,was $180 ,shipping extra .service advisor is Kamran Pelkey
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
Chaincase side is bathed in oil, minimizing the wear to the shaft. The outer seal holds the oil in on the chain case side.
Upstater57
- Apr 25, 2021
- New York
- 2022 Tcat EPS,
2014 ZR9000 (sold)
1978,1979,1980 SRX (sold)
Nothing like good ole' Chinesium for strength and durability. LOL
Turboflash
- Mar 18, 2019
- Southern MN
Caliper bearing has grease in it = more drag and resistance to turning. Chain case bearing has oil in it = less drag = less resistance to turning. Keep in mind it's the shaft that's spinning in the bearing, not the bearing spinning on shaft.Agreed. How do we get the word out that Every ProCross chassis sled should be brought in for warranty service?
- 44K
