Agman 57
- Dec 28, 2006
- Fostoria, Ohio
- 2018 Apex XTX LE, 50th Ann.
2018 Sidewinder LTX LE, 50th Ann.
2017 Sidewinder BTX LE
1992 V-Max 4 (Modded)
2002 ZR 120 G-daughter's
The Apex gauge won't read correctly. I remember another thread earlier in the year. And that fellow was using a Apex gauge and everything worked, but the RPM's read wrong. You have to use the Vector gauge. I really like the looks of it.
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
This is how I did the Vector gauge mounting to the FX Nytro panel. I bought a RAM mount and located it and now have an adjustable gauge!
Drilled the hole pattern into the stock gauge location.
Made an aluminum "backing plate" to give the plastic a little rigidity.
Base installed.
Then I measurened the hole center to center and drilled it into the other end of my RAM mount.
Installed the rubber grommets and screws!
Short, tall position!
Extended reach position!
Base installed.
Mtnviper
- Aug 19, 2003
- Burlington Wa.
- fourstrokesolutionsllc.com
Looks good Allan.
Your going to love that gauge, I know my "old eye's" sure do like it!
stopdropanroll
- Oct 8, 2008
- Fall River WI
- www.styleonecustommotoring.com
Allen, good thought on the mount, how bouncy do you think it will be? I know there isnt allot of suport on that plastic panel.
- Apr 17, 2003
- Menno, SD
- Menno, SD
stopdropanroll said:Allen, good thought on the mount, how bouncy do you think it will be? I know there isnt allot of suport on that plastic panel.
It seems to be pretty solid actually. I thought it would bounce as well, but with the hoods, etc on it all seems to be pretty stable. Only time will tell!
randman516
Allen, it looks great. Would it fit with the turbo gauges on each side of it? Or is it to wide?
- Apr 17, 2003
- Menno, SD
- Menno, SD
I think the turbo gauges would have to be mounted in front of it probably.
Skeeterzx225
I think this is a really cool idea, but is anybody bothered by the miles starting at 0? I'm just thinking down the road when it comes time to upgrade/sell, your mileage will be wrong...how would this effect resaleability?
radianguy
- Jan 1, 2007
I was thinking the same thing! Is the mileage stored in the ECU like on modern vehicles? I would like to do this mod as well, still don't understand why Yamaha skimped on it with the Nytro??Skeeterzx225 said:I think this is a really cool idea, but is anybody bothered by the miles starting at 0? I'm just thinking down the road when it comes time to upgrade/sell, your mileage will be wrong...how would this effect resaleability?
phatkid
I can agree with that to a point..... about milage but what I would do in that case is keep the old cluster from the sled and offer that to the new owner, just to show your being honest and up front why you did the mod...... BESIDES its a 4 stroke miles dont matter to these sleds ......
kizerboy
Nice job looks awesome!!
natedawgedog
- Feb 5, 2011
- DLG, Ak
- something from 2019!
How have these been holding up since you installed it?
giving this thread a bump!
Ive been doing some more research for gauges and came across this thread in search (great tool for finding things on here...
anyways I was wondering how the vector gauges have been holding up for the people that have installed them? still working? is it worth it?
Im wanting to be able to read my tach for better tuning this upcomming winter and the nytro one just doesnt do it for me... any and all input is greatly appreciated!!!
Mtnviper
- Aug 19, 2003
- Burlington Wa.
Re: How have these been holding up since you installed it?
It's holding up great! WAY easier to read the tach, you can see what your RPMs are with just a quick glance. The power band on a Nytro just happens to be with the needle pointing straight up. Or just a hair to the right from straight up if you have some mods done.
The gauge is a little spendy, but I like it so much that I wouldn't think twice about putting another one on!
Bill
natedawgedog said:giving this thread a bump!
Ive been doing some more research for gauges and came across this thread in search (great tool for finding things on here......)
Im wanting to be able to read my tach for better tuning this upcomming winter and the nytro one just doesnt do it for me... any and all input is greatly appreciated!!!![]()
Bill
natedawgedog
- Feb 5, 2011
- DLG, Ak
yea I read that in an earlier post you put up there, it is really spendy, but being able to read everything clearer would be great piece of mind! its 598.98 on yamaha's website parts look up page, ouch!
natedawgedog
- Feb 5, 2011
- DLG, Ak
as far as you could tell are all the readouts accuracy worse/better/same than the nytro gauge?
- 6K
