snobill
- Nov 4, 2012
- Wisconsin Rapids , WI
- 2012 apex xtx
That's gona leave a mark !
You guys are crazy in that boat...LOL
LEE337
Not going to get any tuning done this weekend but here is a pic from Mondays session
That was a solo run. With us two in the boat it was around 47. That's running 5 psi boost and pulling around 8000 rpms. AFRs were still bouncing from 13.6-15.5. I got a new map from rick at oft to try next time out.
lostih
- May 27, 2015
- Vancouver
- 08 Nytro?
Great build thread! I'm thinking of doing something similar. Where did you end up with the impellars? Did the 11/14 make a big difference? I've been wondering how using a jetpump out of a large waverunner would compare to a jetsled about this size....
LEE337
Now with the turbo I am at 14.5/17.5 and want to get a 14/20. 155mm pump I feel is a good choice for the range of imp options.
LEE337
Here is the latest footage
lostih
- May 27, 2015
- Vancouver
- 08 Nytro?
Very cool! How difficult was it to modify the end of the crank to get the pump drive on? Any other gotcha's in the build? If I turbo I'm thinking of using the td04-16t as I use a similar turbo on a small diesel and they are a dime a dozen off of volvos. Is the garret turbo you used off an oem application?
Any idea on the weight of your boat with motor and all?
LEE337
I did not do any modifications to the crank itself. I made an adaptor to adapt a yamaha jet coupler.
Not sure on factory application for the turbo.
The weight is about 650.
The biggest thing is to make sure the bottom is flat with no hook when all done.
vetcorman05
- Oct 27, 2013
- Fairfax,mn
- 05 vector,94 vmax,92 indy, 95 jag deluxe
What does the bottom of your boat look like after your done on the river? How much time do you spend pounding out dents? Looks like a lot of fun anyway.
LEE337
The plastic holds up surprisingly very well. The big hits do take some pressing out but other than that its good.
vetcorman05
- Oct 27, 2013
- Fairfax,mn
That doesn't sound to bad then,cool boat.
LEE337
Summer Video
kinger
- Jan 17, 2005
- Clear Lake, IA
- www.piergenius.com
Takes boating to a whole new level. Awesome!!!
Videos look like a blast.
Nikolai
Awesome!
- 124K
- 6K
- 7K
- 28K
