fxnytroxtx
Guest
Started my sled today and finally NO MORE RATTLE!!!
ViperTurboPete
- Mar 25, 2005
- Sudbury, Ontario
- 2015 Viper XTX LE MPI Turbo
2022 Expedition Extreme 850
The water trick looks cool. I guess we can't tip our sleds over that far.
Beenba
fxnytroxtx said:Started my sled today and finally NO MORE RATTLE!!!
dutchie
thats great to hear ,
i had a hard time trying to buy a puller , shitty day to say the least
well i went and got a clutch puller today from the local yamaha dealer , i should say NOT the dealer closest to me , like 5 mins from my house , they can go screw themselves , i'll never step into that shop again and i'll tell everyone i know to stay clear of the yamaha and polaires Cycle Works dealer in okotoks alberta , they had one but wouldn't let me use it , even after me offering to give them like $200 cash for a deposit to use it for 30 mins and bring straight back as i live only 4 mins from that shop , even offered to buy it outright , Nope , i was a little pissed to say the least ,
as i walked out i thought of the money i have spent in that shop in the last year on parts and stuff alone , funny when you think of it , i'll never grace the steps of that shop again , and i can say i'm sure my buds will pass also after this ,
SO i drove 45 mins to another shop after chatting with them on the phone , let me say a big thanks to the yamaha shop of '' WALT HEALEY''in calgary , was not any trouble from them to lend it out , i had to give him a $100 cash deposit till i take it back in the morning , i see nothing wrong with that , i have bought stuff from Walts shop before , and from now on he will be getting all my money
i tried the rubber o-rings by itself first , never made any differance to me , same old loud rattle , next off came the belt , clutch came off easy with the tool , everything came out easy , i black mark everything just so i know myself it all went back in straight , to clean my groves i used Q-tips , worked really easy , 20 mins and she was bolted back up , now she's sitting for 2 days befor i start it ,
anyone know what the torque is on that main clutch bolt , i just tighten it down as tight as i could get it to seat it on real good , then i backed if off and just did a good snug up on it again ,
can't wait to hear it
Mtnviper
Vendor
Hey Dutchie,
Torque spec on the primary clutch bolt is tighten to 85 ft lbs, then back off the bolt untill its loose. Then re-torque to 43 ft lbs.
Bill
Bill
dutchie
Mtnviper said:Hey Dutchie,
Bill
Bill
thanks , just the info i needed , i think i did about just the same thing , super tight to seat it on good , then i backed it off and just put a good snug on it , will see how it works out for me after 2 days off drying
Supa Dexta
Walts is a great shop.
dutchie
Supa Dexta said:Walts is a great shop.
X 2
Mtnviper
Vendor
Hey guys,
Do you think that the small 10ml bottle is enough of the 680, or should I opt for the larger 50ml bottle?
Bill
Bill
Beenba
10ml should be good. Doesn't take much to fill the splines.
On a side note, we got a touch of snow past few days so I took my sled out for a rip around the yard. I have studs this year so it was hooking really well on the soft grass. Gave it a few hard WOT from stop to test and load up the stub shaft/loctite and everything is fine.
Its so nice listening to just the exhaust at idle now.
ViperTurboPete
- Mar 25, 2005
- Sudbury, Ontario
Now that I know the rattle can fixed, the more annoying the rattle has become. I was out for a ride and I couldn't believe my ears how crappy it sounds. Especially with my foam ripped out and vented.
Mtnviper
Vendor
Beenba said:10ml should be good. Doesn't take much to fill the splines.
Cool, thanks Beenba
nitris223
- Nov 18, 2012
- Yorkton Saskatchewan
- Yamaha Nytro MTX
So does this make the shaft permenant mor can it still be taken out later if need be without to much trouble. New to the yamaha 4 stroke and I have 2 that I was thinking about doing this mod.
Beenba
Please read through the thread I have covered this. It requires heat to remove and likely disassembly of entire engine.
dutchie
I left mine for 4 days to dry in my garage , as i was going away for xmas to be with family , i used the red perma from NAPA , got home tonight , slipped on the belt , started it up , it was super smooth and hardly a whisper from it , not even a small little rattle or ding or knock
i could not believe it , even my wife said holly smokes it's so smooth , and i did it with the whole panel of , all i could hear was the muffler
a big thanks to you Beenba for doing such a good post , and also a big thanks to the guys who came up with it
and like what was said in this whole thread , I can't ever see it having to come off except on a tear down for a rebuild and these 4 strokes last longer then us ,
very happy with my sled tonight
