wavemaster
- Mar 6, 2009
- New Hampshire
- SR Viper XTX, Nytro XTX, Phazer FX
I would say if picky every 1500 or so.
Amen - about once a month right. This will save me a bunch on belts, I used to just toss them between 1500-2000. Not only will this give me a longer usable belt life it is infinitely adjustable without any washers. All in all a good addition.
Maas
- Oct 1, 2014
- VIPER XTX SE
So with this i can slap on an 8DN without needing to machine the clutches?
wavemaster
- Mar 6, 2009
- New Hampshire
Yes, as well as perfect adjustment on the stock belt.
titanrcr
- Jan 3, 2011
- Old Forge, New York
- 2019 Sidewinder LTX LE
2015 Viper LTX SE
2011 Apex
I could be wrong but i thought the secondary machining was to prevent coil bind of the spring. I guess it may not be an issue with an 8DN as it is a longer belt and won't pull down into the clutch as far. Still not clear on what machining is being done on these secondarys...
Only if this mod lets the sheaves get closer together than with the bolts removed. That is unless cannondale's additional plate removal does so.
It does. The 8dn does help but not completely solve stock spring binding. Ulmers spring upgrade does or machining of Helix or area spring sets in.
titanrcr
- Jan 3, 2011
2015 Viper LTX SE
2011 Apex
Well thats what i was thinking, relieving the spring pocket on either the helix or clutch. I'm planning to run a setup that won't coil bind and also plan to run the stock belt. I'm not inclined to machine the secondary, just primary for O/D. I did receive my OSP adjuster today, nice part.
Moravec
- Jun 1, 2014
- 2014 sr viper ltx se
2009 skidoo gade x
Ordered mine was going to order one for my buddy at the same time but the coupon only worked once.
Maas
- Oct 1, 2014
- VIPER XTX SE
ok that sounds great, new to this so thank you for the info,
Which spring upgrade should i do? The clutch upgrade kit for 400$, or just the secodary spring?
I went with the complete Ulmer kit in the interest of supporting a site vendor and also based on reputation.
I also ordered the simple belt change tool to make changing the belt easier and had both clutches machined for full shift/no bind and full range of deflection adjustment.
titanrcr
- Jan 3, 2011
2015 Viper LTX SE
2011 Apex
Can't go wrong with that plan...
yamaha1973
- Nov 27, 2011
- St. Peter Minnesota
- 2014 Viper XTX SE
I would say if picky every 1500 or so. We will see about 8jp. With stock and original Ulmer clutching 8jp needed it every 500 mi. That may change with Ulmers new non binding secondary spring.
What secondary spring are you running?
onestopjim
TY Advertiser
- Feb 22, 2006
- Howell MI
- www.onestopperformance.com
thanks everyone, I have about 25 more left and I will run SRVIPER code until next Saturday the 15th...
Ulmer secondary spring which won't bind even without machining.What secondary spring are you running?
yamaha1973
- Nov 27, 2011
- 2014 Viper XTX SE
What brand spring is it? Looks to be red in color...
