pat the rat
this is what i might end up doing,i thought they were a bit pricey and im not sold on the looks,thanks everyone for theyre opinions,those mirrors are definetly not going on
RedRX1
I ordered the venture lite mirrors. They bolt right on your windshield supports, my father just put them on my mothers sled. They are very easy to see with and don't look too bad. actually they are quite a bit better than the vector/apex/rx mirror options.
pat the rat
if you have a chance to post pics,would be appreciatedRedRX1 said:I ordered the venture lite mirrors. They bolt right on your windshield supports, my father just put them on my mothers sled. They are very easy to see with and don't look too bad. actually they are quite a bit better than the vector/apex/rx mirror options.
RedRX1
I'll be away for 2 weeks, but just look at the Venture Lite on the Yamy site. Fact you may be able to look at them on a Phazer on that site.
phaze5
they sell handguards with the mirror molded right in
Voda2000
- Nov 15, 2006
- Winnipeg Manitoba
- 2007 Phazer GT 136"
You can buy mirrors from Yamaha that mount on bars instead of the windshield mounts. They are the same mirrors but different mounts and a lot cheaper. Plus if you don't want the windshield you can still have the mirrors.
Fast Jimmie
Here's a pic of some mirrors...not sure if they are the factory Yamaha ones or something someone rigged up.
GypsyRoots
Topper said:Why don't you just go with the venture lite mirrors. They should bolt right on your windshield supports.
I agree, that would be my choice...
phaze5
they look like the handguards by powermadd
SledderSteve
pat the rat
wow,long time no see gypsy,i find those mirrors a little high,plus youre screwed when you put the cover onGypsyRoots said:Topper said:Why don't you just go with the venture lite mirrors. They should bolt right on your windshield supports.
scottydog1
I bought a pair of 08 Nytro mirrors for my Fiance's FX Phazer and they are fine. You will have to drill out the tapped holes in the aluminum braces for your hand guards, so you can put the bolts that come w/ the mirror though.
pat the rat
the gt dont come with hand guards
Voda2000
- Nov 15, 2006
- Winnipeg Manitoba
pat the rat said:wow,long time no see gypsy,i find those mirrors a little high,plus youre screwed when you put the cover onGypsyRoots said:Topper said:Why don't you just go with the venture lite mirrors. They should bolt right on your windshield supports.
The bar mounted ones can be rotated behind the windshield when the cover is on so that isn't an issue for them.
- 47K
