XP123
- Dec 25, 2016
- Chautauqua NY
- Sidewinder XTX LE 137
**IMPORTANT**
We have seen one member with shaper bars show heavy wear at the FRONT of his carbides. His sled is a 17. We think the stock soft rubbers may "set in" or "sack" over time. In his case, he added some shims and his setup seems to be better, but he needs more time to watch the wear.
I did my own test(only 550 miles) and with shims added, mine wore too much in BACK of carbides. So in my case the shim was too much, and not needed at all.
We are not sure exactly the differences from his sled to mine, with exception of his is older and may have the rubbers sacked into the pilot pocket more.
My suggestion for new pilot installs, is to follow the original rubber instructions in the Original post. Trimming the rubbers ect as shown here. Run the setup for a couple hundred miles and be sure to check your carbide wear as much as possible in the first couple hundred miles. If your carbides show even wear, with the skis running nicely parallel to the ground then leave it alone. If you show wear at the front of carbide then add some 1/4 shims(Bergstrom). This may be something that needs to be updated as time/miles goes along. What works on season 1, may need slight shimming by season 2 as the rubbers sack/conform into the pilot pocket.
Please post your results in this thread and over time we will have a good handle on the shimming.
Dan
Good post Dan and another thing that needs to be considered is how some riders have their springs and shocks set up. Also what conditions are they riding on? There are way too many variables to have a set up that works the same across the line. What you have come up with is an excellent starting point and those who follow need to understand that they may have different results and may need to adjust to their particular sled and riding style.
Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
Mine are not shimmed Dan and my carbides are wearing even. this is after 1500 miles.View attachment 136220
Looks great Joe! Because I went with 5.7's & have more support under rubber, I too am going to hold off a bit on shimming the skis and review.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
Agree.....I had another conversation with powderfalcon this morning on phone to ask more variables....Good post Dan and another thing that needs to be considered is how some riders have their springs and shocks set up. Also what conditions are they riding on? There are way too many variables to have a set up that works the same across the line. What you have come up with is an excellent starting point and those who follow need to understand that they may have different results and may need to adjust to their particular sled and riding style.
His is ltx and mine rtx, but many with ltx have good wear, like Toms is still running orig carbides but I still have not put my own eyes on it yet, Tom did tell me they are not worn thru though.
We all just need to watch them far before they wear....I sorta put mine thru the test for my own benefit to see how long the big shim would go, and it never did 'set in' like I thought it would. So im gonna pull them and heavily modify them to sit down into pocket, just enough to keep bottom of rubber from pressing down into pocket.
But It does seem many without any shims are having decent wear.
Dan
Revitup600
- Jan 13, 2018
- River falls, wi
- 2018 Sidewinder ltx le 50th
So without reading through all 41 pages here.... When installing a doo ski, do the Yammi rubbers still need to be trimmed on the underside?
Thank you
Thank you
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
Thank you
Josh,
Yes, I trimmed all of the outer bottom rubber off on mine as I was not concerned, nor did I want heel pressure on my skis using Snowtrackers. I also did not rotate the Doo bushing around as the skis bolted up nicely.
LouTurbo
- Dec 19, 2016
- Vaughan, ON Canada
- 2017 Sidewinder LTX LE, Hurricane Tune on the fly
Pilot Skiis,
- Woodbridge, ON
I am picking up Doo rubbers tomorrow that I ordered.
Where can I expect to trim ? On the top surface do I match the profile of the Yamaha rubber lower radius for the ski leg with the lowest radius position of the Doo rubber ?
SumpBuster
- Jul 18, 2003
- Carlisle, NY .
- 18 sidewinder; 06 Apex RTX
Haven't read all the posts, but has anyone tried filling the void with epoxy or something to make a nice flat surface for the rubber?
nadekeys
- Oct 20, 2009
- Green Bay, WI
2009 Apex LTX GT
2008 Nytro MTX Turbo
I was wondering about this too.Haven't read all the posts, but has anyone tried filling the void with epoxy or something to make a nice flat surface for the rubber?
Sent from my SM-N950U using Tapatalk
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
Just read the first few posts of mine....its all there as I always edit in any changes.So without reading through all 41 pages here.... When installing a doo ski, do the Yammi rubbers still need to be trimmed on the underside?
Thank you
Dan
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
Just read the first few posts...its all there, nothing has changed.I am picking up Doo rubbers tomorrow that I ordered.
DOO rubbers are not preferred and will be alot of work.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
Not really needed. The original setup works well....just watch your wear and if you need shims over time, add them as needed but so far no shims seem to work fine for many, and I have gone to a thin bergstrom 1/8" shim to test with.Haven't read all the posts, but has anyone tried filling the void with epoxy or something to make a nice flat surface for the rubber?
Teamsynergy
- Feb 14, 2016
- Indiana
- 13' Ski-Doo 1200 Gade
18' Yamaha Sidewinder LTX-SE 137"
I will be using a 8xxx series 3M epoxy on mine. Will report the results later.
LouTurbo
- Dec 19, 2016
Pilot Skiis,
- Woodbridge, ON
Thanks Dan.Just read the first few posts...its all there, nothing has changed.
Threeman03
- Nov 1, 2015
- Flushing,mi
- 2016 Yamaha sr viper ltx LE
Same exact thing with my orderDan and all-
Just a heads up that something is going on with BRP and their inventory of skis... I ordered the 6.9's and I received (2) 6.9's but one without the ski loop and one with. Also, the bushings were noticeably different.
Here are the pics... https://www.dropbox.com/sh/rn6tfou69x4ggej/AACWOT_wdTNhtk5xw0hRAcgSa?dl=0
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
My guess....BRP is running out of 6.9s finally.....they have not been made for many yrs.
Get them soon boys! Or just use 5.7s work well too.
Sorta like my dealer just old me all 8DN belts are on backorder! Must be US HERE ON TY4stroke putting these sled companies into a tizzy with our mass posts....lol
Dan
Dan
- 23K
