stingray719
01/13/2015 - Pioneer Performance (716-496-8800) is now handling this kit, ask for "clutching on the cheap" NOS-PRO, or Stingray mod clutch, its the same thing.
1. New 8fp weights, 3.6 gram rivet, GWG spring, spring shims, $178.32
2. Same as above with 45/39 helix $263.27
NOTE: Helix has spring pocket cut to eliminate coil spring bind, no machining of secondary's is needed to prevent spring bind in the secondary clutch.
Shipping to Canada available
Prices at time of posting, subject to change.
dfroster
- Dec 18, 2003
- Kronenwetter, WI
- 2022 Arctic Cat Thundercat EPS
Is the kit for use with the stock Viper belt exclusively or can it be used with the 8DN? If it can be used with the 8DN, will modifications to the kit be required?
stingray719
You can use it with the 8jp belt but if you are upgrading you really should use the 8dn. No modifications to the kit to run 8DN belt.
weasel33
Stingray, I thought it was a46-40 helix. Is 45-39 any better?
Curtis Chambers
- Nov 19, 2014
- 2015 SRViper R-tx-Le
Must not be on website yet was go to check shipping cost to Canada. I'm going to need it lol
stingray719
Use either, kind of depends on which one you can get a lot of vendors are sold out.
stingray719
I checked with Bruce at Pioneer today and he said yes they ship to Canada.
Curtis Chambers
- Nov 19, 2014
Thanks for checking it stingray719 I'll check site
stingray719
Just set this up with them on Tuesday, I wouldn't expect to see it on the site yet.
Curtis Chambers
- Nov 19, 2014
That's why I can't see it, I will check back with them later thanks again.
sxr70001
- Dec 4, 2010
- Michigan
- Sidewinder LTX SE
SR Viper RTX SE
How many shims come with the kit? Just curious.
stingray719
Should be the glide washer kit with 5 washers each measuring a hair over 1mm, but ask them when you call.
fc8464
- Aug 4, 2014
- Fairbanks, Alaska
- 09 Summit
15 Viper MTX 153 blue/white
Would that helix or the factory helix be better for low elevation mountain sleds ( stock 153 ). Fred
stingray719
I have not tested it myself in the mountains, but NOS-PRO (Terry) ran that helix when he was here in Colorado last Thanksgiving. Terry can you answer this one please?
Groomer08
stingray, does this setup raise or lower the clutch engagement speed? i feel as tho stock is too high already. its like riding my nytro with the parking brake left on...
