- Nov 11, 2016
- Cedarville, MI
- Cedarville, MI
Just finished a Stage 4R tune for a customer. This tune is nuts at 320 horse pump fuel and 337 horse using race fuel. The welds on the header are perfect laid coins (welder talk), it is the most horsepower tune out there.
Thanks to all our customers that we have flashed tunes for
Need a quality tune with adjustable launch control, knock alert, dash upgrade to watch your sleds boost and recall max. speed, boost and rpm. It will also give you AFR readings, but the AFR module from Precision EFI must be used and is sold separately. Thunder Products Clutching can do this for you!
STANDALONE DASH REFLASH
Our dash upgrade standalone includes both a graph bar boost gauge as well as a large numerical boost gauge. We've added the ability to record peak boost, RPM and top speed reached during a run. This is displayed on a page added to the left panel on the dash. An AFR gauge is also included but you will need our AFR module package to be able to see it (sold separately). This product will work on any flash you have including stock.
This dash reflash fits all 2017 & up 998 turbo engine
- arctic cat 9000 series ( zr9000 , M9000, XF 9000, thundercat )
- yamaha sidewinder - srx / l-tx / m-tx / x-tx / b-tx
Tunes with the best clutching out there and you will be smiling
